proportioning(combination) valve question
Old Sep 29, 2014 | 04:16 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
So one of the ports stripped out on my proportioning valve to the front brakes. I am planning on a temp fix to get my car on the road and have a quick question. I have all the parts needed to Tee off the front lines and bypass the valve for the front. I was going to continue to use the proportioning valve to control the rear and leave the front holes unhooked. My question is if I maintain the valve for the rear and leave the front unhooked from the M/C will it leak from the valve? I would think it must be completely separate chambers. Is the valving between the front and rear inside the prop valve completely separate/isolated?
Any help would be appreciated. Thanks!
Old Sep 30, 2014 | 04:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: proportioning(combination) valve question
The combo valve shouldn't leak with all of the front ports open. However, due to the age of the valve it may.
The differential switch will close and set the brake light, so unplug the connector until the valve is replaced.
RBob.
Old Oct 3, 2014 | 08:21 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Thanks for the reply. I am going to order a new one, but I'll give it a shot with a Tee for now. I guess I'll know if it leaks pretty quick.
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
