89-97 Rear Caliper Brackets
Car: 1996 Firebird
Engine: 3800 Series II
Transmission: 4-speed Manual w/ OD
Anyone use 93-97 brackets on a 89-92? They appear to be the same - but GM lists them as different part numbers.
Engine: 4++,350 & 305 CIs
Re: 89-97 Rear Caliper Brackets
GM went to a cast iron bracket in 93 or so
There were 2 designs. The early 89 bracket was a 2piece part with a small stamped steel center and a dust shield.
The late 89 2nd design is a little larger stamped steel 1 piece design (no dust shield) that was brought in to help stop brake moan with light pedal pressure while backing up.
Car: 1996 Firebird
So the 89-92 is stamped (or forged) steel - whereas the 93-97 is cast?
Yup. Both work the same. If you search i think i have posted pix of the 2 early designs.
Car: 1996 Firebird
But is one "superior"?
The 89-92 1LE bracket p/n was also used on the C4 until 96. The 93-97 LT1 is a different p/n. But both look the same except the LT1 has numbers "cast" in.
Depends on what you want it to be superior at?
Car: 1996 Firebird
Well - I think I found the answer - the 1LE and C4 bracket has a zinc phosphate coating (black) and the LT1 is zinc (silver).
Are you talking about the caliper carrier bracket or the mounting bracket? Think we may be talking about 2 differe5 things.
Car: 1996 Firebird
ambainb
Apr 25, 2016 09:21 PM
Genopsyde
Nov 11, 2015 10:46 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Dialed_In
Aug 20, 2015 01:45 PM
