Drum Brake help needed!
Old Feb 17, 2015 | 02:04 PM
Quinn P's Avatar
Car: Firebird Formula
Engine: 305 tbi
Noob here to the 3rd gen world. first firebird
i have a 1990 firebird formula. 305 tbi 5 speed manual. i bought the car recently and all is almost good. except the rear brakes as a whole. all of the springs, plates, adjusters etc have been removed and put into rubbermaid containers by the PO (Previous Owner). i am in search of diagrams on how to reinstall them. new wheel cylinders were just installed by me, i just need to see a "how to" on all the springs etc.. Thanks
Quinn
Old Feb 17, 2015 | 02:13 PM
couchmotors's Avatar
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
Re: Drum Brake help needed!
go buy a manual from the store. they have diagrams in there for just such a thing. also you can buy what is called the hardware set or kit (all the springs and pins) and they are color coded some of them come with everthing and they are about 15-20 bucks per side, plus every thing will be new and while your add it buy new pads if you have not already. pads with brake fluid on them are a bad thing. most of the time the kits have diagrams in the box also. hope this helps
Old Feb 17, 2015 | 10:23 PM
Quinn P's Avatar
Engine: 305 tbi
I have a Chilton manual and cant seem to find any type of diagram in there at all. Is chilton a bad brand for a manual?
Old Feb 18, 2015 | 12:04 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Hopefully between the three pics it'll come together. Good luck.
Attached Thumbnails Drum Brake help needed!-drmbrk.jpg   Drum Brake help needed!-drmbrk1.jpg   Drum Brake help needed!-drmbrk2.jpg
Old Feb 18, 2015 | 12:42 AM
Night rider327's Avatar
Car: 1988 Camaro
Sign up (for free) on autozone.com and you can veiw repair manuals their site.
Raise and safely support the vehicle.
Remove the wheel and tire assemblies.
Remove the brake drum.
Remove the return springs.
Remove the hold-down springs and pins. Remove the lever pivot.
Remove the actuator link while lifting up on the actuator lever.
Remove the actuator lever and lever return spring.
Remove the shoe guide, parking brake strut and strut spring.
Remove the brake shoes and disconnect the parking brake lever from the shoe.
Remove the adjusting screw assembly and spring. Remove the retaining ring, pin from the secondary shoe.
To install:
Any part or spring which may appear worn should be replace. The short shoe (primary) should be installed to the front of the vehicle and the long shoe (secondary) should be installed to the rear. After complete installation of the brake shoes a clicking sound should be heard when turning the adjusting screw or self-adjuster. Do not switch parts from the left or right brake assembly, the adjusters are designated Left and Right.
Clean dirt from all parts and wire brush raised pads on backing plate. Lubricate backing plate pads and adjusting screw with brake grease.
Install the parking brake lever on the secondary shoe with the pin and new retaining ring.
Install the adjusting screw and spring. Lubricate the adjusting screw with brake (white) grease.
Clean and lubricate the contact points of the backing plate. Install the brake shoe assemblies after installing the parking brake cable on the shoe.
Install the parking brake strut and strut spring by spreading the shoes apart.
Install the shoe guide, actuator lever and lever return spring.
Install the hold-down pins, lever pivot and springs. Install the actuator link on the anchor pin.
Install the actuator link into the actuator lever while holding up on the lever.
Install the shoe return springs. Install the brake drum. Install the wheel and tire assemblies.
Adjust the brake and lower the vehicle. Check emergency brake for proper adjustment.
Attached Thumbnails Drum Brake help needed!-0996b43f8020e2cb.gif   Drum Brake help needed!-0996b43f8020e2cd.gif   Drum Brake help needed!-0996b43f8020e2cf.gif   Drum Brake help needed!-0996b43f8020e2d0.gif   Drum Brake help needed!-0996b43f8020e2d1.gif
Old Feb 18, 2015 | 12:43 AM
Car: 1988 Camaro
here's the rest of the pics
Attached Thumbnails Drum Brake help needed!-0996b43f8020e2d3.gif   Drum Brake help needed!-0996b43f8020e2d4.gif   Drum Brake help needed!-0996b43f8020e2d5.gif   Drum Brake help needed!-0996b43f8020e2d7.gif
Old Feb 18, 2015 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Look for a GM shop manual specific to your car. You'll be ahead in the long run, especially if you intend to work on your car (and keep it for any length of time).
JamesC
Old Feb 18, 2015 | 07:10 AM
Quinn P's Avatar
Engine: 305 tbi
Appreciate the fast replies! those pictures should do it NightRider
Last question
---- when buying fittings ( going from Wheel cyl --> T <--- Wheel cyl ) what fittings should i get? metric i read on here is used after 1984. this true? Thanks.
To clarify i meant fittings at the wheel cyl? they didnt come with any.
Old Feb 18, 2015 | 04:49 PM
Car: 1988 Camaro
Yeah the '84 and later cars had ISO metric bubble flared brake fittings
IROCZ1989
Jan 24, 2016 03:55 PM
AkDrifted
Aug 17, 2015 07:45 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
