Early Style Rear Caliper Rebuild with Recall Kit
Old Feb 28, 2015 | 10:07 AM
Firm's Avatar
Car: 84 Camaro 2.8L, 85 T/A 305 LG4
I need to rebuild the rear calipers on my 85 T/A. I ordered one of the few remaining recall/repair kits from GM to repair the well-known E-brake adjustment problem. The kit (P/N 18019028) arrived today and I believe it's missing a few parts. Here's what it did come with:
-Two new pistons
-Two new springs
-Two new pad to piston clips
-ONE new piston seal
I am sure I am missing at least one piston seal, but is there anything else that I am missing?
The second part of my question is; if I purchase a standard caliper rebuild kit now, will it have the rest of the parts that I am missing? I've never done a caliper rebuild before so I am not 100% of everything I need.
Here's a photo of everything that came in my recall kit:
Old Mar 3, 2015 | 03:26 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: Early Style Rear Caliper Rebuild with Recall Kit
Seals to worm screw would be useful and seal between parking brake lever and caliper and piston seal.Coni seal #ck108243 has the seals you need(rockauto)
Old Mar 3, 2015 | 08:39 AM
Firm's Avatar
Thanks man. I've actually already gone ahead and ordered a Dorman rebuild kit, but I figure it should have most (if not all) of what I am missing.
Old Jan 19, 2016 | 09:03 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
I just received my recall kit and it had a complete rebuild kit! I didn't know it came with everything to rebuild it completely! Plus the guy at Elway Chevy in Englewood, Co(where Car Craft mag gets their GM tech info.) says there are plenty left. I paid $42.00. The box looks like a collectible....
Old Jan 20, 2016 | 07:14 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
So does this actually make the handbrake to work properly ?
I believe a special tool is needed to pull out the piston right ?
Old Jan 20, 2016 | 07:26 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I done this recall kit to my 85 T/A. Yes it works well. On taking the pistons out, you just ratchet/rotate the brake arm on the caliper while in a vise. then watch the piston FLY across the garage at 80MPH!!! Then re-install in a vise or use those fancy visegrips shaped like a horse shoe.
Old Jan 20, 2016 | 11:21 AM
Johnny*G's Avatar
Car: 1987 Trans Am
Anyone know how to install those silver rings that are on the right of my picture? they are pad dampers?
Bob is correct, just rotate the parking brake lever. I had a stubborn piston so i unbolted the park brake lever then took a 10" piece of 1"x2" wood and set it where the outboard caliper goes, tap on the threaded end lightly to create room to get air into the chamber, and shot a little air into the rear of the caliper. Now, with that being said, DO NOT have your fingers near the pistons face. unless you have too many fingers...
Old Jan 20, 2016 | 11:28 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
They clip onto the piston to sorta hold the pad in place. Another note.....When you install the pistons in the caliper, be sure it is rotated in the right orientation to accept the little tab on the brake pad! Very important! Been there, done that!
Old Jan 20, 2016 | 12:25 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Didn't This Recall Only Pertain To Manual Transmission Cars,I Think I Still Have The Original Recall Letter From GM If I Can Find It To Check.
Old Jan 20, 2016 | 12:33 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yes it was, but automatics before 89 needs them too
Old Jan 22, 2016 | 10:44 AM
RaceFace's Avatar
Car: 1987 F-bird
Engine: 350 Vortec
Transmission: Manual
Old Jul 14, 2020 | 03:33 PM
GTA 1987's Avatar
Car: GTA 1987
Engine: 5.7
Hi ,
can you help me with this recall kit.
i need it ......have no rear brakes.
Roger.
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
