Options with 1LE hubs
Car: 1987 Trans Am
Hey guys. I made a set of 1LE hubs in anticipation of a big brake upgrade because I wanted the extra width with my rims. I'm not seeing much. Anybody know what my options are with these hubs?
Thanks, Ryan
Thanks, Ryan
Car: 1987 Trans Am
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Options with 1LE hubs
Any brake upgrade will work with the same parts, just need to space the caliper brackets 5/16 or so outboard to match the hub and rotor offsets.
I used a Baer 6s setup with a custom hub and the correct spacers for the abutment brackets.
Car: 1987 Trans Am
wasn't sure if it is 1/4" or 5/16" thicker that the bracket needs to be. I'm trying to search for the difference in front end width between standard and 1LE equipped cars.
Car: 86 Trans Am
You can use the same brackets, then simply purchase shims (washers, but built for shimming) the correct width. McmasterCarr for example sell a variety.
No sense using heavier, thicker brackets
Car: 86 Trans Am
I used almost 5/8 in shim, worked just fine
Car: 1987 Trans Am
Car: 86 Trans Am
I was running custom hubs, 1le offset plus another .25 offset added to the hubs when then were built.
