C4 HD PBR caliper interchange
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm looking to change out my 12" C4 front brakes for the C4 HD 13" versions. Question I have is are the calipers for the 12" the same as the calipers for the 13" or will they have to be changed out? I've got the rest of the parts necessary and wanted to find out about this before I started the swap.
Car: check
Engine: check
Transmission: check
Re: C4 HD PBR caliper interchange
They each use a different caliper due to the rotor thickness difference. That is .80" for standard and 1.1" for the HD rotors.
RBob.
RBob.
Car: 90 Formula
Another question I didn't think of till I just went through the fitment sticky is can I use the C4HD brakes on 17" TT2 wheels?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I think the clearance minimum at least for j65 is 16 .
I think saw blades are 17″.
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
I have 13" C4 rotors on my Z-28 with the PBR calipers, NOT the Baer Brake branded calipers, and they fit inside stock 16" IROC rims. And yes, the calipers for the C4 HD brakes are different than the standard C4 12" rotors due to rotor thickness. Also, I believe the cage/carrier for the caliper is different. I would need to confirm that in my garage at a later time.
Engine: 4++,350 & 305 CIs
Are the non HD calipers for sale?
Sure do... A pair of calipers and carriers.... what are looking for?
Non HD Calipers and carriers if dual piston, fairly clean and reasonable on price.
I will take a pic or two and post them up here a little later.....
Here is what I have...
Are those something you might be interested in?
Possible, need to do some checking on a few pictures I have to see if its exactly what I need.
Let me know. They are the non-heavy-duty calipers and carriers, for the 12" diameter, narrower rotors. PM me.
Car: 90 Formula
Another question has popped up: do I have to use the 1LE hubs or can I use the regular hubs that came with my original C4 kit with the 13" HD stuff?
Rob Dog
Sep 3, 2007 05:01 PM
Rob Dog
Dec 31, 2006 02:59 AM
