1Le Front Brake question
Car: 92 Formula
Transmission: BW 5 Speed
Should the caliper/pad holding brackets be installed so that the pad retaining pin is on the top or the bottom?.....I have seen pictures of them both ways!!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1Le Front Brake question
I'm puzzled by your question, so perhaps the following pics will be useful.
JamesC
JamesC
Car: 92 Formula
Thank You...The pictures answered my question.....the caliper retaining pin should be at the bottom of the caliper....I wasn't sure because I have seen the calipers/brackets installed with the retaining pin on top...Cheers!!
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
You should have 2 pins... 1 pin each one on top one on the bottom.
Engine: 4++,350 & 305 CIs
Nope, only 1 pin. The pads hold caliper on other side of caliper. Its a quick change design for track use.
Pics are worth a thousand words, I'm told
JamesC
.JamesC
RA080923
Aug 30, 2002 03:13 PM
CrazyHawaiian
Aug 3, 2002 09:55 PM
