Yes another proportioning valve question.
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
My car is an 85 and has this style proportioning valve. Can the spring upgrade be done to this style also? The plug is on the bottom not the front like the square style valve. I do know the lines are metric like the newer style valve.
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Yes another proportioning valve question.
I do not know but it might be worth swapping to the new style valve...
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Check the thread on the cheap-proportioning-valve-upgrade thread. There has been different styles discussed. IIRC, the answer is yes. However, you may want to review the Calculating Brake Torque thread once you identify your components to help you decide which spring you want to use.
Car: 85 Berlinetta
This is true, you could always switch types. Heck, since it's all out you could install and adjustable style.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
You should be able to upgrade that style. It still works on the same principle, you may just need a different diameter spring.
Car: 85 IROC
Engine: 5.7
Axle/Gears: 4.11 torsen, 4th gen rear
I have the same prop valve in my 85 iroc. I put a tilton prop valve after this one in line, use them both, Works great.
Does anyone know why the larger line from the master cylinder feeds the rear brakes? This is opposite from every other car or truck I've seen. Typically the larger line feeds the front brakes since the front brakes are larger and have 2 separate lines running from the combination/prop valve. I'm sure there's a reason for this but I can't figure it out.
Car: '89 Firebird
Engine: 7.0L
I think the larger rear line is carryover design from the drum brakes. Not needed for disc brake but doesn't hurt anything either. That's the rumor I perpetuate anyway.
3.8TransAM
Oct 21, 2003 09:26 AM
BuckeyeROC
Sep 12, 2002 12:24 PM
SSC
Feb 14, 2002 09:11 AM
