LS1 conversion bracket question
Old Sep 4, 2019 | 07:54 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
I will be cutting my own brackets for a swap. I need to know the correct thickness Steel plate I’ll need. Thanks
Old Sep 4, 2019 | 09:34 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Re: LS1 conversion bracket question
.375" I just measured mine I got from Bigbrakeupgrade.com.
Old Sep 4, 2019 | 11:00 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Actually the thickness can vary I had bigbrakeupgrade make me a skinner set so that my rotor was center in the caliper carrier. If cutting it your self I would mock it up and figure out the exact thickness you need to center the carrier on the rotor.
Old Sep 4, 2019 | 12:02 PM
Was your set 5/16” thick?
Old Sep 4, 2019 | 12:46 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Don't recall
fireburdluvr85
Brakes
Mar 16, 2013 07:00 AM
seiplentz
Brakes
Dec 9, 2011 04:19 PM
Jaysz28
Brakes
Sep 28, 2008 10:16 AM
fast377
Brakes
Feb 11, 2007 11:29 AM
luke j
Brakes
Jan 31, 2006 09:24 PM
