Wheel stud length
Old Sep 19, 2020 | 02:23 PM
91CamaroRS454's Avatar
Car: 1991 Camaro rs
Engine: 454
Wheel stud length
I have 17” wheels and Planning on doing bigbrakeupgrade ls1 hubs and brackets with powerstop calipers, pads, and rotors. I don’t like the look of open ended lug nuts and was unsure if I should get the 2 or 2.5 studs. Let me know please
thanks!
Old Oct 3, 2020 | 01:01 PM
PTS's Avatar
PTS
Car: 89 Vert Camaro
Engine: 3.8SFI Turbo
Transmission: 200R4
Re: Wheel stud length
I have this same setup, I am taking it off and will be selling it if you are interested and didn't buy it yet
Old Oct 3, 2020 | 01:43 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
If 91Camaro is not interested I might be! I am looking to update mine brakes all around. Looking for 12" LS1 up front so I can use my new 18" rims and go back to my stock 16" Formula ones if I desire.
Old Oct 3, 2020 | 01:44 PM
Engine: 5.7
Axle/Gears: Stock
thanks!
This is question I have as well. I am planning on getting all the parts over the winter to update my brakes all around, budget is tight. So I can install by spring next year.
Old Oct 6, 2020 | 07:52 PM
PTS's Avatar
PTS
Car: 89 Vert Camaro
Transmission: 200R4
PM me if you are still interested.
Old Feb 13, 2021 | 09:34 AM
unionbill's Avatar
Car: 1986 Trans Am
Transmission: Automatic
Axle/Gears: 2.77
thanks!
I'm searching for the same answer. Did you ever find out which length is best with stock or closed end lug nuts? Thanks
Old Feb 13, 2021 | 11:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I used the Dorman on the C4 standard brake swap with the stock lug nuts and covers:
Studs:
10 pcs, napa 6411581 cross reference to dorman 610-323
Motormite 98501
Dorman 610-323
They are 54mm long (about 2-1/8"), .509 knurl with an 8mm shoulder.
RBob.
Old Feb 13, 2021 | 08:09 PM
Car: 1991 Camaro rs
Engine: 454
2” for stock size wheels even with the added space for the conversion. 2.5” is if you’re running over sized wheels with spacers
Azrael91966669
Brakes
27
May 26, 2016 01:49 AM
ebmiller88
Brakes
Jul 7, 2007 06:36 AM
cc 82Z-28
Brakes
May 23, 2006 09:39 PM
Drkhrse89
Brakes
May 21, 2005 05:58 PM
ebmiller88
Brakes
Aug 31, 2004 03:41 PM
