LS1 brake swap bolts
Old Dec 27, 2023 | 11:09 AM
taguy16's Avatar
I'm trying to decide which bolts and hardware to use for my front LS1 brake swap to hold the adapter bracket to the spindle and caliper to the bracket. Big Brake Upgrade just gives you eight plain head bolts - with no washers of any sort - to hold everything together: I'm thinking this might be a bad idea. Since these bolts have to provide a lot of clamping force wouldn't it be better to have some sort of washers under the bolt heads, or to just use flange head bolts? On the rear LS1 brake swap I did with factory parts from a 2001 Camaro GM used flange head bolts to hold the Caliper on. Although to hold the abutment bracket to the caliper GM just used plain bolts (with large heads) and no washers.
Has anyone reading this done this swap, and what type and length of bolts did you use? Thanks.
Old Dec 28, 2023 | 06:48 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: LS1 brake swap bolts
I did that swap last year and I used plain bolts no washer. If you use what Big Brake Upgrade uses you will be good.
Old Dec 28, 2023 | 10:40 AM
taguy16's Avatar
I'd say you'd want to use plenty of Locktite on the bolt threads then so they don't vibrate loose.
Old Dec 28, 2023 | 11:18 AM
taguy16's Avatar
Looks like the original LS1 front calipers were attached to the spindles with bolts that had washers under their heads:
Old Dec 28, 2023 | 11:35 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Nope. No washers.
rdsxfn524
Brakes
Oct 17, 2014 04:54 PM
88FormulaKiller
Feb 4, 2011 11:03 AM
89 Iroc Z
Brakes
Jul 10, 2005 02:39 AM
3.8TransAM
Brakes
Dec 19, 2004 11:57 AM
z28cdoyle
Brakes
19
Nov 16, 2004 08:30 PM
