Rear disc brackets
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Rear disc brackets
It appears Ed Miller isn't in business anymore.
I did this one about 15 years ago and I forget how. Converting a drum rear to factory disc. I can't remember if the bottom two bolt holes for the drum backing plate is the same spacing as the disc backing plate?
I know Ed used to sell special conversion caliper mounts that were 3 bolt. Does anyone sell those for either the delco calipers or pbr ?
-- Joe
-- Joe
Car: '82 Camaro Berlinetta
Engine: 305 Carb
Transmission: TH200
Re: Rear disc brackets
I've been wondering the same thing.
In my searching I noticed a couple of companies (The Right Stuff and LEED) both offer kits that look like they use the Delco caliper (or something similar) and SSBC-USA uses a Ford Varga series caliper.
Would love to find brackets for drum to PBR.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I may end up just using drum brakes if I can't find what I want but.
Engine: 305 Carb
Transmission: TH200
I'm not 100% sure they are the Delco but they look like they may be from the pictures.
LEED https://www.summitracing.com/parts/leb-rc1009
The Right Stuff https://www.summitracing.com/parts/rsd-afxrd82
SSBC-USA https://www.summitracing.com/parts/tsb-a125-46bk/
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
https://www.speedwaymotors.com/GM-7-...ake,36673.html
I believe those use 78+ full size car calipers, which are larger than the thirdgen delco calipers. (hence why they don't work with 15" wheels).
Engine: 305 Carb
Transmission: TH200
I think you are correct, I have not given much thought to the 15" wheels as i'm still rocking the factory 14" and have a set of 16" rims for when the time to get new tires comes.
If someone has the drawings for the PBR brackets, I may be able to get a local shop to price out a run.
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
This would be a long shot but Tobin at kore3 may be able to help. When I did my brake upgrade he had so many options he could machine. He was extremely knowledgeable. The system I got from him was perfect. I'm aware your looking for more stock stuff but he has much more than is in his website.
you could also look at fly n bye. They have brackets similar.
Looked at fly n bye, I think they actually have what your looking for.
Engine: 305 Carb
Transmission: TH200
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have some spare PBR calipers with parking brake cables, so I could technically use them but I'm nervous that they won't fit these old school drag wheels and I don't think they will fit the wheel opening on my thirdgen to try them.
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
Hi everybody,
I have the Flynbye drum to disc conversion brackets (HFConvBkt12). I also have a set of PBR calipers (18-B4345/46). I bought these parts long time ago and I can't find any documentation. Can I use the PBR calipers with the Flynbye brackets? Thanks
Axle/Gears: 9-bolt/3.45
Hassle free drum rear disc conversion to 1LE/ LT1 PBR rear brakes - Third Generation F-Body Message Boards
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You should scan them to an image so we can have more cut on the CNC machine since he's out of business.
Car: 1990 Iroc z-28
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So I'm trying to figure out if the allstar 7.5 10 bolt conversion brackets work with Seville calipers.
The brackets say they work with metric D154 calipers. I *think* the seville calipers are D154 with a parking brake. (D154 is the same as our front calipers).
Car: 1990 Iroc z-28
ebmiller88
Brakes
May 14, 2007 11:11 PM
prockbp
Mar 2, 2004 06:30 AM
