Canadian Region Take off to the Great White North.
Ceramic coating
Old Jun 3, 2010 | 12:02 PM
5speed's Avatar
Car: 86 IROC
Transmission: 5 speed
Axle/Gears: limited slip
Ceramic coating
Just a FYI.
Anyone looking to get headers coated..
I had mine done at Hi-Tech http://www.htmcoating.com/Home/tabid/36/Default.aspx
They did a great job. Great service and fast turn around time.
Before.
After.
Old Jun 6, 2010 | 02:53 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Ceramic coating
They look great!
I also had some headers coated last week but from Top Gun coatings in calgary, they look ok just the coating is very thin and scrapes off kind of easy. Not really impressed they are nothing like my Jet Hot coatings I did to my other headers.
Old Jun 6, 2010 | 03:14 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Ceramic coating
Originally Posted by Tony89GTA
They look great!
Often times they are not fulley cured till after they are installed and run for a while, and will scratch easy.
unless its a big pro shop they can heat cure it fulley.
Old Jun 6, 2010 | 08:30 AM
5speed's Avatar
Car: 86 IROC
Re: Ceramic coating
Mine were heat cured..he has an oven there. I taped them up though when I installed them just in case..
Old Jun 6, 2010 | 01:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Ceramic coating
to what temp???
I have done my own ceramic, you can buy enough to do 100 header for $30, only need a cheap air brush to apply, and it takes temps of 700F+ for an hr to be half cured and like 1000F+ for another to be fulley cured. I asked, what if I bake at 700+ for 4 hours and they said nada, justhalf cure em then be careful on install and they will fully cure then.
Cause usually its a powder shop that offers it, and their ovens aren't made for them temps, gotta have a special one for that high n why most will scratch easy till installed n cured at higher exhaust temps of 1000+
Old Jun 6, 2010 | 08:56 PM
5speed's Avatar
Car: 86 IROC
Re: Ceramic coating
I'm not sure what temp he cured them at. He did tell me to make sure I cleaned them before I started the engine after I installed them..so they might not have been completely cured. I found a finger print on one of the collectors.
Old Jun 6, 2010 | 11:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Ceramic coating
That would be a good clue in, it wouldn't do that once fulley cured.
Its not a big deal but its like the big secret to ceramic coated exhaust parts.
treat em like they are made out of glass till installed and run hot for a while.
Old Jun 7, 2010 | 01:05 AM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Re: Ceramic coating
They look great!
Good to know, I was going to take my headers to Top Gun, if you don't mind me asking what did he charge?
Old Jun 7, 2010 | 01:10 AM
Tony89GTA's Avatar
Car: 89 GTA
Re: Ceramic coating
Good advice but looking at my coating more it just pisses me off just how thin of a coating they put on. There is just a huge difference in quality from my Jet Hot coated headers.
Cost was $240 plus GST
Old Jun 7, 2010 | 02:39 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Ceramic coating
It depends on the type of coating, reg plain ceramic coating is suppose to be ubar thin, why you use an air brush.
but there are chunky kinds.
But reg ceramic is real thin, you get like a small 40z thing of it for $30 shipped and it wont take but a pop bottle cap full to do some headers.
It can air dry and be installed but its gonna be super easy to mess up.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
