My Stereo randomly pops
Old Jun 24, 2002 | 12:27 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I was driving today and i started hearing a loud pop come form either my subs or rear speakers it would do it randomly. Then when i got home i put it in park it popped again so i put my car in drive popped put it in park popped. I checked all my wires and connections any ideas what it could be? I also started hearing a little enigne noise in my rear speakers which ive never had before.
Old Jun 24, 2002 | 12:54 AM
RiceBurner's Avatar
Check your grounds. Also, check your battery terminals.
Bret
Old Jun 24, 2002 | 08:54 AM
miked's Avatar
Any chance one of your speaker leads is grounding out somewhere like back my the 6x9's?
Old Jun 24, 2002 | 07:32 PM
FAST RS's Avatar
My 6x9 and my subs are runing off of 2 different amps but getting there power from the same sorce. Today i turned my steering wheel i herd it pop. Then i closed my center counsle i herd it pop. Put it in gear herd it pop. Then it goes away and magicly starts popping again. I checked connectiosn from the battary. I cant find were my amp is grounded to ive tried in the past to find it but was never able to. If it is a ground problem would me turning my steering wheel cause it to pop?
Old Jun 24, 2002 | 10:11 PM
RiceBurner's Avatar
It sounds like you have a loose wire. A slight bump or movement of the car will make the wire loose the connection. Just go over your system with a fine tooth comb.
Bret
Old Jun 24, 2002 | 11:01 PM
RiceBurner's Avatar
Do you have a capacitator in your car?
Bret
Old Jun 24, 2002 | 11:50 PM
FAST RS's Avatar
No basicly its a wire from the battary going to my first amp then i have another amp wire that goes from the first amp to the second amp so the second amp gets power. Same with the grounds havent had any problems with it in the 2 years ive had them til now.
Old Jun 25, 2002 | 01:22 AM
RiceBurner's Avatar
I have no clue what the problem is. I would rip every piece of audio equipment out and start over.
Bret
Old Jun 25, 2002 | 09:09 AM
miked's Avatar
The center console and shifter are awfully close to the deck. Could it be back there. This might not be the smartest thing but sometimes when something like that happens I'll turn on the system and go around bumping on things until I can locate the source. A good pop could mess up your speakers though so I'd be careful.
Old Jun 25, 2002 | 06:49 PM
FAST RS's Avatar
You got it today on my brake i kicked the side by the stereo and it popped then i kicked it again lkept doin it so i know its behind the head unit just gotta get off my *** and go see whats goin on back there now.
Old Jun 30, 2002 | 08:54 PM
squirrelybird's Avatar
i have been having the exact same problem for some time now, except i have no subs or amps. it totally went away for a while but is back now. wish i could offer some help but have no ideas. im ready to replace ALL the wiring.
Old Jun 30, 2002 | 09:57 PM
FAST RS's Avatar
Well when i wen tback there i was in wire hell... Were i put electrical tape aroudn my conections the tape came off and the amp wires were loose that go to my EQ so i taped them all up and put the RCA cables back in and no problems now.
Old Jul 1, 2002 | 12:13 AM
Ragnarok_Tyr's Avatar
Are you using a common ground? If not, you can get ground loop hum. I switched to both power and ground distribution blocks, using 4-gauge for both, and that eliminated all my hum problems.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
meeklay812
Oct 1, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
