Which subs
Old Jul 14, 2002 | 01:44 PM
blibby69's Avatar
Which subs
Which do you all think I would be happier with. Two infinity kappa perfect 12"s (1000 rms) or 3 Jl audio 12w6's (900 continious)?
Old Jul 14, 2002 | 02:43 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
go jls..they are the best in the sub market imo...
they smoke anyone and everyone!!
post pics in your decision!
iroc2nv
Old Jul 14, 2002 | 05:32 PM
mudaholic's Avatar
what kind of amp? what kind of music do you listen to? you going for sq or spl?
Old Jul 14, 2002 | 08:38 PM
blibby69's Avatar
Most likely a kicker xs100. I listen to rap mostly, I want sq mostly I used to have 3 12w6's and it was more than loud enough, I just was wondering if anyone has heard either and which they preferred.
Old Jul 14, 2002 | 09:54 PM
mudaholic's Avatar
i prefer infinity perfects, they are spectacular sq subs.. have you looked at the adire brahma? or the image dynamics idmax?
Old Jul 15, 2002 | 09:48 AM
Polecat's Avatar
Just be sure no matter what speaker you go with,to get maximum power out of the Xs100, it'll need to be a 1 ohm load. max power should be or exceed 1200 watts. So be sure to get a woofer to handle the power.
The Perfects are great SQ woofer, but won't hold massive power. I would look at the Brahma or IDMax.
Old Jul 15, 2002 | 02:21 PM
mcss383's Avatar
ditto to the brahma or max, better power handling and SQ imo.
Hey Polecat, check your PM's.
Old Jul 15, 2002 | 03:01 PM
Polecat's Avatar
Sup? I did...shows I don't have any PM's?
Old Jul 15, 2002 | 04:24 PM
Ted J's Avatar
Re: Which subs
There really isn't an answer to your question if you ask me. I would suggest you go and listen to some yourself and see what you think.
While others on here have given you their take on things in the end, unless they know you and know the tastes of your ears, you are the only one that will really know which subs will make you happy after you listen to them.
See if you can find a stereo shop that has some of the subs you speak of above in premade boxes. Talk them into letting you put them in your car and take a listen so you can 'try before you buy' sort of thing. Each speaker, and speaker placement for that matter, is going to sound a certain way in your car so this would give you a better idea than that of a showroom. Try to put the sub(s) in about the same location as you'll have it once you put it in your car.
Hope this helps!
Ted
Old Jul 15, 2002 | 09:19 PM
mcss383's Avatar
Click the 'show all' or whatever it says.....maybe something messed up. Oh well....
Anyways, what i was wanting to know, is the new KX amps as underrated as the ZR amps were? (ie rate them @ 400 but they put out 725). Also, will you be attending the Heatwave? I plan on meeting up with Ed Martin (good friends with Biggs) and checking out Bigg's car.
Old Jul 15, 2002 | 10:49 PM
pronger44's Avatar
3 W6's will handle a lot more than 900 watts jl subs are veary underated
Old Jul 15, 2002 | 11:39 PM
blibby69's Avatar
Yeah thats 900 continious so add about 15% to figure rms. They also are gonna release a w3v2 http://www.c-a-r.net/modules.php?op=...thread&order=0 . So I dont know which Im gonna go with.
Old Jul 16, 2002 | 08:00 AM
Polecat's Avatar
Yea, I did that and nothing...hmmm...
But yes, the new KX amps are just as under rated as the ZR's. IE, the KX1200 is rated at 1200@1ohm, but will do closer to 1400 watts, maybe as high as 1500 watts.
Yea, I will be at Heatwave as well....taking off tomorrow to be with the family first, then we all leave thursday morning.
I'll see ya there!
Tracy
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
