Question on Sound Deadening Material
Old Jul 20, 2002 | 07:32 PM
GoldenSwordZ28's Avatar
I just wanted to know, would 120sq feet be enough to cover the entire interior of my car including roof (Hard Top)? And is the Raamat stuff really as good as the Dynamat (I'm not a guy with a competition stereo, I just want some good deadening)?
Oh! And also, will it keep down the heat around that Cat area in the passengers side? Just wondering
Thanks!
Adam
Old Jul 20, 2002 | 09:25 PM
mcss383's Avatar
120sq ft should be enough. I have used ~150 and I have 2 and even 3 layers in some places on my Monte Carlo.
I haven't used Dynamat Xtreme firsthand, but there is no way it can be better than Raam60. Raam sticks like no other (don't let it touch ANYTHING but what you want it to stick to), its WAY WAY cheaper than Dynamat, has NO smell, and is pretty thick.
Also, if your wanting to quieten your cabin some (loud exhaust?) then go to www.foambymail.com I just ordered 100sq ft of 1/8" thick Volara (under closed cell foam, $60 shipped) and it helped reduce exhaust noise A LOT (headers, cat, 3" pipes and 2-chamber Flow's)
Old Jul 20, 2002 | 11:22 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i've heard nothing but good things about raammat. if you need something a little more easily available, try peel and seal from home depot or lowes. about $1/ sq ft and works as good or better than some of the other sound deadeners. i covered the back half of the car with 25 sq ft, so 120 should be enough.
Old Jul 21, 2002 | 02:29 AM
Neat I think I'll be going with the Raamatt after hearing that. Oh, and that Volara stuff, should I put that on top of the Raamatt? Not quite sure what your doing with it or suggesting I do with it But I'm all ears. The quiter, the better.
I appreciate your input guys!
Adam
Oh yeah, that peel and seal stuff, is it anywhere near as good as Raamatt? Cause If I'm gonna be spending the money, I might as well go with Raamatt if its gotta better results.
Old Jul 21, 2002 | 12:54 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i have yet to do a side by side, but because peel and seal was a little easier for me to get, i got it instead. they are all pretty much similar, but i believe the raammat is thicker, so go with that.
Old Jul 21, 2002 | 09:21 PM
mcss383's Avatar
Yes, put the Volara on top of the raamat (or whichever deadener you use). You will also need glue to put it down. Willwood glue (the one in the red container Flammable, non-flammable is JUNK) you can get it at Home Depot (gallon or quart).
Old Jul 22, 2002 | 11:41 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
How much weight will 120ft^2 add to the car??
Brian
Old Jul 23, 2002 | 08:03 AM
mudaholic's Avatar
lots
Old Jul 23, 2002 | 11:13 AM
mcss383's Avatar
way more than you want if your goal is to be real fast w/o a seriously HO motor. But hey, if your wanting a quiet, good interior for listening to the stereo, its well worth it.
Old Jul 28, 2002 | 05:58 PM
Iroc87's Avatar
I went to Lowe's last night to look for the peel and seal stuff, Couldn't find it to save my life. Anyone got a brand name for it or at least where to find it (what aisle/section in lowes)????
Old Dec 22, 2004 | 12:47 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
is weather lock similar? i found that at lowes but cant find anything else
Old Dec 22, 2004 | 02:48 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
I just use grass as sound deadening material. Thats right grass the kind that grows outside your window.
jk btw
Old Dec 22, 2004 | 03:45 PM
PontiacRacing's Avatar
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
Where can you get this Raammat stuff? I might be redoing the carpet in my car soon and I want to add some sound deadening material while I am at it.
Old Dec 22, 2004 | 10:13 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Guys, please do yourself a favor and don't use peel and seal. Sure, it's asphalt stuff that will deaden sound, but just wait until summer comes around. You'll have that stuff melting and falling off the ceiling, not sticking too well on the sides, and making the whole car smell like it was just paved. Get Brown Bread, Raammat, or even Dynamat (ike sound has the Extreme Bulk pack for 50% off). I'll probably be going with RAAMmat since I've heard more good things about it next to Dynamat. Here's a mini review of the stuff by a guy on another forum. You can get it from raamaudio.com or off of eBay.
Old Dec 23, 2004 | 07:27 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I'll never go back to using any of the above..
Lizard Skin is the only thing id use anymore.
http://www.chillylizard.com/LizardSkin.html
Not only a Insulator but sound deadening also.
http://www.hotrodscustomstuff.com/PS-LizSkin.html
Old Feb 23, 2005 | 12:25 PM
TMX's Avatar
TMX
Car: 84 & 92 Z28s
Engine: 305 carb & 305 TPI
Curious about the weight this stuff adds when doing the floor, cargo, and inner quarters. If you had to ballpark it, would you say fifty pounds, a hundred pounds, three hundred pounds....?
Thanks,
-Bob
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Golfvette
Aug 24, 2015 06:35 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
