Really what is the difference between a DVC sub and regular one??...
Old Aug 14, 2002 | 11:47 PM
ChevyLuva3's Avatar
I noticed on Kicker Comp VR 12's (preferably), that you have a choice of a regular voice coil, or dual ones? And no difference in price. Whats the difference? Why would I want a DVC, why would I want a regular one??
Thanks.
Old Aug 15, 2002 | 12:04 AM
mcss383's Avatar
Simple, flexability. If you have an amp that puts out its max power @ 2ohm mono and you have a SVC 4ohm sub, you aren't getting the max power out of your amp. Now if you have a 4ohm DVC sub you can wire the coils in parallel, get a 2ohm load and get the max power out of the amp.
If you have 2 DVC subs and an amp that makes max power @ 4ohm mono you can achieve that load (series coil and parallel subs, assuming the sub is dual 4ohm coils), if you had 2 4ohm SVC subs you could either get a 2ohm load or an 8ohm load not the 4ohm you need.
Old Aug 15, 2002 | 12:12 AM
ChevyLuva3's Avatar
...Sooo its win-win if I get the DVC's right?
Old Aug 15, 2002 | 01:22 AM
CrazyHawaiian's Avatar
Car: too many ...
Its depends on the setup dude. DVC's will cut your ohm load in 1/2 as opposed to SVC's. For some people thats a good thing, for others it means the amp will run at odd ohm loads like 1.5 or even .5 (not good unless U got the right amp). It really depends on the amps you want to run, and choosing between DVC or SVC will allow you to get the most out of your amp.
Give us more info on the rest of the setup ..
Old Aug 15, 2002 | 07:48 AM
Polecat's Avatar
In a word, yes, you will get more out of a DVC over the SVC. More flexability, as well as most of the time, power handling.
Go for the DVC VR's......you won't be disappointed.
Old Aug 16, 2002 | 02:52 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Im not disapointed and listen to Polecat he knows what he is talking about :hail: and he has a sick *** gmc truck
Old Aug 16, 2002 | 02:56 PM
Polecat's Avatar
Chevy....
Old Aug 16, 2002 | 03:00 PM
CD MaroMan 91's Avatar
what kind of amp are you gonna use?
Old Aug 16, 2002 | 03:06 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Oh my bad i could of swore i saw a GMC logo on the fron tbut after i look at it again it is a chevy. Im not gonna mess with that truck. not untill i get my ls1 and weither my stroker, heads and cam, or blower. And then i would have to make it out to OK>
Old Aug 16, 2002 | 03:08 PM
Polecat's Avatar
That's cool...just playing with ya...
yea, found someone that wants my Sportsman II heads, so I may sell them and get the Dart Aluminum Pro 1's, and change cam to a Comp 294S solid...mo powa!
Old Aug 16, 2002 | 03:26 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
oh jeasus. then you better get permission to take off from air traffic control.
Old Aug 17, 2002 | 12:55 AM
ChevyLuva3's Avatar
Thinkin the jbl1200.1
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BumpaD82
Feb 26, 2016 02:57 PM
Jorlain
Oct 8, 2015 01:57 AM
toronto formula
Sep 10, 2015 07:31 AM
