Drivers side lockbox airspace
Old Sep 12, 2002 | 12:50 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
Anybody know about how much airspace i can get if i build a box from 3/4" MDF in the driver's side lockbox space? Thanx. Just a general estimate will be good enough.
Old Sep 13, 2002 | 03:19 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Probably about .3 cu.ft.
Old Sep 15, 2002 | 08:07 PM
Engine: 5.0L
i really would like to build a stealth box there for my Boston Pro 10 and i wanted to make one out of mdf so i could have it stashed away until i got the chance to build one out of fiberglass. i dont have the time to build one out of glass since im in college, away from my trusty garage. i cant put one in the passenger side because i need the spare, and i dont want pay someone to build one, i want to do all this myself, just like my kicks. any suggestions? Thanx.
Old Sep 16, 2002 | 09:48 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
If you really want to do it yourself, I would suggest making a temporary box either above your gas tank, or in the well. It would be a lot easier. Besides, it's only temporary right?
Old Sep 16, 2002 | 11:26 AM
Engine: 5.0L
yea, i got a premade box just jammed back there right now. i guess i will just leave it like that till i can build the glass one. thanx.
Old Sep 24, 2002 | 03:13 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
If you are going to get "crazy" with your system I would recommend putting a second battery in the drivers side lockbox. You will need to put a brace under the bottom to support the battery though.
Old Sep 24, 2002 | 03:21 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
You mean like this?
Old Sep 24, 2002 | 03:26 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
yep, exacalty as REZN8R picture shows.
Old Sep 25, 2002 | 12:42 PM
White Ninja's Avatar
what does the wiring look like for the extra battery? does the power cable go to the original car battery and the neg goes to the body of the car?
Old Oct 2, 2002 | 05:23 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I moved my battery from the front to the back. I just ran 4 ga from the battery to the main wire that used to hook up to the battery when it was up front. The negative side is grounded to the chassis. If I were to do it again I'd use a bigger gauge wire, but I already had 4 ga. ran through the car.
Old Oct 2, 2002 | 07:18 PM
that's a lot of wire hanging out of that airspace.
Hey Rez, my dad has a sh-t load of ground wire i think for housing. It's not as finely stranded as speakers wire, it looks like there's about 10-15 strands - 4 guage. Would this work fine for running from pos to a distribution block and have 2- 8awg outs?
Old Oct 3, 2002 | 09:42 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
It would work. The thicker strands of wire actually increase conductivity. The fine stranded automotive type is mostly for flexibility when installing in a car. House wire will work, but it'll be harder to install and won't look very nice.
Old Oct 3, 2002 | 11:27 AM
true, but it's just flat black wire... so... i guess it won't be too bad, but people might get confused as to what's going on with it. black wire = ground... red wire = pos...
ah, whatever, i'm out to impress anyone with my wire... just my sound.
Old Dec 13, 2008 | 04:10 AM
lighthorseozzy1's Avatar
Re: Drivers side lockbox airspace
I noticed the extra battery in your (thumbnail picture) lock box. What did you do to support the battery in place? Do you have any other pics on the Battery support? I greatly appreicate this. I have a 1986 Firebird. Thanks..Ozzy
Old Dec 13, 2008 | 12:09 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Wow, six year old thread!!
Yeah, I have a battery back there too. Installation required removing the plastic trim panel (yes, the one with the door in it), then removing the cardboard lining of the "box" (the battery is too big to fit through the door). I then had brackets bolted to the floor area behind the trim panel and the battery installed and clamped down before the trim was reinstalled.
Old Dec 13, 2008 | 08:45 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You could always yank out the spare tire and mount the battery in its place using a BMR battery relocation bracket.
Old Dec 28, 2008 | 01:10 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
i had a 82 ta that i removed the cover and made a plexi cover and had my crossovers and fuse blocks inside looked real good
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
LittleFranks
Sep 17, 2015 12:22 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
