CD player not hungry
Old Sep 21, 2002 | 11:47 AM
BillD91RS's Avatar
Can you fix a cd player once it decides that it won't accept CD's any more. It takes them in and then spitts them back out again. This is a JVC cd player that I got a couple of years ago. Is this something that I might be able to fix or is it DOA?
Bill
Old Sep 21, 2002 | 01:00 PM
87z28TN's Avatar
Car: 1987 Camaro Z28
Have you tried Reset
I am not sure that this will help, but have you tried to reset the inernal controler inside your CD player. There is usually a button behind the face plate that is used for reset purposes.
I hope that this helps.
Old Sep 21, 2002 | 04:53 PM
BillD91RS's Avatar
Could you please elaborate a little more on what you mean. I'll go take my face plate off the front and look for a button. what exactly do you mean by "internal controler"?
Bill
Old Sep 21, 2002 | 05:03 PM
deadtrend1's Avatar
he means its a little tiny button that usually is hidden on the faceplate somewhere. It small enought hat you have to use a pin or paperclip to push it. It resets the unit.
BUT, how long does it take to spit it out. Does it eject it right after you put a cd in, or does it take it in, spin for a second or two, then eject it?
Old Sep 22, 2002 | 11:53 AM
BillD91RS's Avatar
It takes the photo in for a second. I can't tell if it spins it or not then spits it back out again. Is there any way that I can clean the CD player? Might that help?
Bill
Old Sep 22, 2002 | 01:21 PM
deadtrend1's Avatar
yea, go to best buy, circuit city radio shack, k'[mart yada yada and get a cd player lens cleaning disc.
Old Sep 26, 2002 | 08:46 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
DON’Y USE A CD CLEANING DISK! I see this all the time, the cleaning disks will actually knock the lens off the optical pickup. BillD91RS, your CD player most likely already has a bad optical pickup (The laser part that reads the disk). If you take it to an honest shop they should be able to fix it for like $150 or so, depending on what pickup is used in your player. JCV just used two for the most part, ones a little more expensive then the other.
Old Oct 6, 2002 | 05:09 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.73 (for now)
I have the exact same problem as you and I also have a JVC cd player... Is this a common problem with JVC's or are other brands just as bad?? I know my friend has had a Pioneer for about 6 years without 1 problem....
Old Oct 7, 2002 | 06:52 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
This is a common problem with all CD players. But like every thing some are better them others. Pioneer is one of the most durable head unit out there, is just that simple. But even Pioneer pickups go bad and they break for other resins. 6 years is a long time for any pickup. An optical pickup will more or less “eat” itself over time.
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
kairles
Oct 26, 2015 09:13 PM
Linson
Oct 1, 2015 09:50 PM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
