Whats your Ground
Old Oct 18, 2002 | 08:36 AM
Greg Kuhlmann's Avatar
Whats your Ground
I just had a custom box built. the other day when i went through my car wiring everything up (again) i thought it wouldnt be a bad idea to just have my ground going to my spare tire. the little nut that screws down on it to keep it in place is what it is grounded to. seems to be working fine. can anyone tell me any reason why i shouldnt use that as my ground.
Old Oct 18, 2002 | 08:45 AM
coalyard's Avatar
Because you might have to use your spare tire one day. Besides that, a stereo system, properly installed, should not interfere with the normal operation of the vehicle.
Old Oct 18, 2002 | 09:53 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by coalyard
......... a stereo system, properly installed, should not interfere with the normal operation of the vehicle.
Just the way you wrote that, you sound like a school teacher or something.
I feel like I'm sitting driver's ed. watching one of those stupid movies.
"While driving the vehicle, be aware of your surroundings at all times. An emergency situation could arise at any moment. Stay alert!"
LOL!!!!!
Sorry, but that's what it reminds me of. Just the way you worded it I guess.
AJ
Old Oct 18, 2002 | 01:36 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I used the big bolt towards the front of the car in the spare tire well.
and like coalyard said, it would suck if you needed to use it and you had to undo the amp hook up the tire and then try and hook up the amp again. Just put it somewhere that you can, "set it, and forget it"
Brian
Old Oct 18, 2002 | 11:47 PM
mypurple92rs's Avatar
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
LOL!!!!!
AJ
and would you use your spare tire i think i would rather walk than risk death on dounuts
Old Oct 19, 2002 | 10:26 AM
CaysE's Avatar
Death on Donuts! Tonight at 11, only on Fox!
Hahahahaha! Damn Fox network loves to air those disaster shows.
Anyway, I have my own grounding point question. At one point I had wired the ground for my amp to the metal bracket underneath the passenger-side rear seat. There was already a screw hole waiting for me, so I filed it bare and used that. I did have some problems with the amp when I had my headlights on (or any more-than-normal current draw on the battery), but I was never able to check the resistance of that grounding point. Does anyone know if that is a good spot to use for my reinstallation?
I suppose I'll go out and buy a multimeter, but just thought I'd ask.
Old Oct 19, 2002 | 10:42 AM
BadMunky87TA's Avatar
hmmm, so what about the subbox that is sitting in the well?
depending on subs, it can weight anywhere from 60-120 pounds, that might interfere with getting the spare out
Old Oct 19, 2002 | 11:46 AM
ninety1TAgta's Avatar
LOL!!!!!
AJ
lol I thought the same thing after reading that! I think its all . Its more like, a properly installed stereo system should make you happy, not break or cause fire . It all depends on how far you want to take it. If you want a sub box in the hatch or spare tire well, there goes function already... Its like saying that, proper engine mods shouldnt hurt your gas mileage. Sure headers, porting etc will help your mileage, but if you want to take it further you can boot mileage out the door. Same thing with stereo systems. And another thing, grounding your system there wouldnt stop you from taking out your spare, you just couldnt listen to your music while you take the tire out thats all.
About the ground, thats the same spot I have mine grounded. No spare tire either, so I guess I got an improper sytem. heh.. I put a bit bigger bolt than stock and roughly sanded what I could to make sure its a good contact. The bolt is also longer so I could put a nut on there and tighten the ground between the nut and the bolt head.
greg
Old Oct 19, 2002 | 11:55 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
My setup was grounded at the same place where the electric hatch was grounded at. One bad speaker took out the whole system though and now it is no more....gone....fried....broke.....pissing me off.......
Old Oct 22, 2002 | 11:19 PM
okay i have a flat tire... 99.9% of people are not going to change the tire. fire up the car and start blarring there music! if you think about it... I'M going to go slow and listen to see if i hear any weird noises from that donut... I think its a good idea to ground from the spare tire... makes the ground wire short, and its just one wing nut to loosen!
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
