Isobarik question
Old Dec 16, 2002 | 11:31 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Isobarik question
I was looking at some setups and starting to think a bit. If I have 4 12s setup in isobarik do I have to have enough air space for four 12s or two? I am guessing air space for four. I was looking at some 12s and they dont require a whole lot of space, so If I was able to keep the box low enough I might be able to fit four if I did an isobarik box.
Any info would be appreciated,
Brian
Old Dec 17, 2002 | 01:43 AM
mudaholic's Avatar
say you have one sub that uses one cubic foot. when you iso-group two, you effectively half the airspace--in other words, the two subs would now only require 0.5 cubic feet of space. now, you know that using 2 iso-groups will sound essentially the same as just using 2 subs, right? the only advantage is that you only need half the airspace. what subs are you planning to use? because double the amplification and twice the subs.. thats pretty damn spendy.
Old Dec 17, 2002 | 08:29 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
An isobarac arrangement can also sound better because you have 2 cones moving with a static air pressure between them. This provides a more linear motion of the voice coils and less physical distortion of the cone. Is it audible? Probably not.
Old Dec 17, 2002 | 11:09 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Isn't it true that he won't gain any SPL at all?
Let's say you're putting out 130dB with two 12"s. By adding each sub you're theoretically increasing the SPL by 3dB per sub (or 6 with two subs). You're also increasing the amount of output by lowering the load on the amp. Let's say theoretically you're doubling the wattage by doing that. That's ~3-6dB for 2 subs. So now you're up to a 9-12dB increase right? Wrong.
By putting them isobaric, you aren't gaining any cone area into the listening area, so scratch the 3 dB from that. And you are still increasing the amount of wattage, but the 'rule of thumb' is a LOSS of 3 dBper woofer in an isobarik setup. So scratch that 3-6dB gain from that.
So you're not gaining much, if any SPL, but you're pushing the amp harder so you're using more power from the batt/alt. All you're gaining is the control that Jim mentioned, and like he said......
I've also heard/read that you only need 2/3 the size of a sealed box when running isobarik.
.67 cu.ft instead of 1 cu.ft to compensate for the added area of the second sub.
Old Dec 17, 2002 | 11:20 AM
AJ_92RS's Avatar
Here's more info that I found on Isobarik setups. It's long, but it should help.
When it comes to Isobarik designs, there is really one big plus gained by trading off two costly minuses:
The BIG plus (The Good):
A really small box that produces a whole lotta sound!
Costly Minus #1 (The Bad):
Two drivers cost twice as much as one and you must double your amplifier power to achieve the same loudness level compared to a non-isobarik design. But, since the box can handle twice the power, you're right back where you started, only twice as poor.
Minus #2 (The Ugly):
Since the drivers are arranged in a "clamshell", the frame of one of the drivers can be seen extruding from the outside of the box which, quite frankly, is as ugly as sin. However, if you have the money, and enclosure SIZE is your main concern, then this design is indeed for you! Also keep in mind that building an additional box for the mid-bass WILL be necessary! LITTLE or NO mid-bass will be produced from the clamshell design! The question is, are you willing to sacrifice the money (and ugly) to achieve big time sound from a relatively tiny enclosure (the parallel here being an expensive and cosmetically challenged companion who can do quite a number with a golf ball in a garden hose).
However, we can treat The Ugly:
How? By installing the two drivers like this: (in a “tube" facing the same direction)
Now, the speaker is MUCH more aesthetically pleasing! In fact, no one can even tell that there's two drivers in the box! And, you won't have to build an additional box for the midbass! Unfortunately, that's about it for the good news...
As you probably suspect, there simply must be a trade-off here somewhere... And, you're right. Let us now venture into a little number-less math.
First of all, let's explore the theory behind all this Isobarik gibberish. Essentially, when you load two identical drivers Isobarikally, in effect what you're doing is making one "monster" driver by combining the two. What I mean by this is that since the two drivers are always "helping" each other (they are physically "coupled" in an airtight chamber and are wired in parallel so that they always move in unison to the electrical signal applied to them) as they work, then the math says that the two drivers can be (and are) considered as ONE driver acting alone, only with half the Vas rating. That also amounts to half (-3dB) the SPL, and twice the Power rating as compared to ONE of the drivers acting alone.
Ok, so, where does this help us and, more importantly, where does it hurt us? Well, the Vas being cut in half is definitely a plus (that's why the box size is cut in half as compared to a single driver), but the SPL being chopped by 3dB (effectively in half) sucks, but that can be made up for by the power handling capability being doubled (of course, you gotta fork out more bucks for a more powerful amp). So, essentially, you can "buy your way out" of this drawback.
This brings us to The Ugly. By using the "pretty" Isobarik design, we win on pretty. But, we lose a little on box volume and "high" (or more accurately put..."extended") power performance.
The "loss" on box volume is this...instead of having half the sized box, we have half the sized box plus the extra space needed by the frame of the front woofer. Unless you're dealing with a woofer which already "defaults" to a really small box (already has a really low Vas), however, this "loss" may not be so bad. Depending on the size of the woofer that you're dealing with, this added volume could be anywhere from 0.25 to 1.5 cubic feet, so you must decide whether or not "pretty" is worth it.
The other loss we must deal with is the loss in overall speaker performance over extended high power demands. Here's the scoop... When you're really cranking out the sound from your favorite CD, the woofers are working hard, and are therefore generating alot of heat. This is natural. So, ask yourself, "where does a woofer generate heat?". Well, it generates heat in the voice coil (which is inside the big round magnet). And, when any object heats up, its physical characteristics inevitably change. Look again at the diagram of the "pretty" isobarik design:
Now, doesn't it seem logical that the voice coil (magnet area) of the front woofer has less "natural" cooling opportunity than that of the rear woofer? The answer, of course, is yes. And, since we're on the logic bandwagon, doesn't it stand to reason that if the voice coil of the front woofer is alot hotter than that of the rear woofer, that the characteristics of the two woofers would be different? You guessed it, yes again.
Ah, but here come the "so what?" 'ers. Well, when you consider that the whole idea behind Isobarik is based upon two identical woofers "working as one", but now one of them is alot hotter (and is therefore responding differently to the electrical signal being given to it) than its counterpart, then it's not hard to imagine that your "benefits" of Isobarik design are quickly going down the tubes.
Given these facts, any competition audio professional would tell you not to design an Isobarik box in such a fashion. However, if you're just trying to get good, deep bass out of a small box, and this small box is to be in view of your friends and family, then this design is quite ok! Remember, it's only after extended periods of high power demands that you begin to see the deterioration effects of this phenomenon.
If you are an average Joe who wants a good sounding box, but who doesn't intend on cranking it up for extended periods everyday (while being monitored by a competition judge and his sound equipment), then you can beat The Ugly, no problem.. Like Clint says, "A man's GOT to know his limitations." Personally, I've used this design for many years with no problems, but I had to include this information to satisfy the "purists"...
As touched on above, this "pretty" configuration also has the added benefit (over the clamshell design) of being able to produce more mid-bass/midrange frequencies, since the front (voice coil) of one of the driver cones is able to radiate that acoustic energy from the box, and therefore you will probably be able to get away without having to build an additional mid-bass box.
Likewise, if you go with the clamshell design, keep in mind that building an additional mid-bass box is an absolute necessity. There will be little or no mid-bass produced by this design. This clamshell design along with an separate mid-bass box will most certainly out perform the "pretty" design by itself, but now you have to build more boxes. Again, it all comes down to pluses and minuses...the name of the game is "trade-off". If there were a perfect speaker design everyone would use it, and you wouldn't be reading this...
Old Dec 17, 2002 | 12:46 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Thanks for all the info guys.
I hadnt really picked out 4 12s that I wanted. I was just thinking that alot of people have two 12s in there cars, so why not four. If I can spend the money on a better set of 12s I will do that instead. Or maybe I will try and squeez three of them back there.
Of course I have to wait to do all this til my lady gets her own car to drive, "I dont want you to take up all the trunk space with stupid speakers" But she does like the bass.
Thanks again
Brian
Old Dec 17, 2002 | 03:05 PM
White Ninja's Avatar
can someone clear up the isobaric design? i'm not familiar with it, thanks
- Andy
Old Dec 17, 2002 | 03:30 PM
mudaholic's Avatar
EDITED: see below post
Old Dec 17, 2002 | 03:33 PM
mudaholic's Avatar
theres actually quite a few options--you can do some pretty crazy stuff with isobarik setups.
clamshell:
piggyback:
planar:
back to back:
Old Dec 17, 2002 | 06:04 PM
that's really freakin weird.... i like the 2 subs sharing a box idea...
- Andy
Old Dec 17, 2002 | 06:11 PM
mudaholic's Avatar
its definitely a cool concept, but like was mentioned above: you end up buying 2 woofers and having to double your amplification power--and yet it still sounds the same :-/
Old Dec 17, 2002 | 06:19 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
that was long aj but very helpful. i wasnt really interested in doing that but its nice to know if it comes up.
by the way, in our cars, a regular sealed enclosure is more than enough most of the time. maybe a vented design but an iso or bandpass is not really necessary or beneficial in my opinion.
Old Dec 17, 2002 | 08:42 PM
mudaholic's Avatar
just in case anyone was wondering, i added the names of the different isobarik designs to my above post so you can match the pictures up with the post AJ gave.
Old Dec 17, 2002 | 08:47 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I had only seen the clam shell design, I didnt know isobarik could be done so many different ways.
Brian
Old Dec 17, 2002 | 09:14 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Just to let you guys know....
I had a buddy that was a master at building an isobaric bandpass. He built a box for another one of my buddies with 4 JL 12W1's in it, powered by a PPI 150x2 bridged at 4 ohm=600watts. It hit 136db. You can get 2 10's to do that. But I will say that it definately did not sound like 136, more like 145. The interior resonance was wicked, your shirt jiggled around on your chest from outside the car!!! BTW the sound quality was awesome. Not typical of Isobaric enclosures.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
