need help mounting
Old Dec 31, 2002 | 01:05 AM
Garett92Z's Avatar
need help mounting
MY AMP! heheheh.
Okay guys, seriously, I have a Kicker XL 405 D Amplifier (5 channel) this thing is a fricking beast. 18" long by 10" wide by 2.5" tall... what do I do with it? What's the best way? My insurance company will not cover my stereo unless it is all securely fastened with bolts, nuts, or screws. I want a really clean install job. I was thinking right up on top flat part in the hatch but the gas tank is right below it so that is a negative.
any other ideas? I would go look but my car is 2 hours away from me right now so I can't really visualize it well.
anyone? advice?
also: will my amp need a capacitor do you think?
Thanks a MILLION guys I am not too knowledgeable at audio stuff.
garett
Old Jan 1, 2003 | 12:02 AM
5.0L1992RS's Avatar
I think the best way to mount a large amp is to get a 1/4" or 3/8" piece of wood and put it between the carpet and the gas tank area. Then just mount the amp to that piece of wood using 1/4" or 3/8" screws (depending on size of wood). This way it is well mounted and your insurance should except it.
Old Jan 1, 2003 | 12:54 PM
chevkid's Avatar
Car: 87 SC
Transmission: t5
I remember someone saying if you use screws that are very small in length you could mount it there.You could do some creative stuff if you mount it on a board.
Old Jan 2, 2003 | 12:48 AM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
I installed mine in the glove box section on the left in the back (w/ the lockable door). If I can fit my amp and cap and distrabution block in there, I think you can fir yours in there, and ya you will need a cap and bigger wires if you have stock alt.
F.Y.I.<Picture was taken before I installed my cap and got the other amp for my mids/highs, so i didnt need a distrubition block either>
Old Jan 2, 2003 | 01:02 AM
Garett92Z's Avatar
ack! okay so i guess I need a capacitor... what farad do I need?
okay my amp is huge it's 18" long by 10" wide by 2.5" tall... do you think that'll fit? My car is 2 hours away so I can't do a test fit... could someone maybe measure for me to see if it'll fit somehow? pleeeeeease?
thanks for the replies so far
Old Jan 2, 2003 | 08:19 AM
5.0L1992RS's Avatar
I don't believe that your amp will fit in the glove box. That is where I have my CD Changer and i have a couple of inches of padding on both sides so i would say it is about 6-8 inches wide. How many amps RMS is your amp?
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
