Infinity Kappa Or Aline Type R?
Old Jan 12, 2003 | 05:36 PM
91GTA350's Avatar
I am having trouble deciding between 2 12'' infinity kapa subs and 2 12'' alpine type rs. Both are duel voice coil. The Ininity Kapa 120.3 DVC are $120 each on ikesound.com and the alpine swr-241d are $115 each.
Please let me know which subs you think I should get.
Also, would it be ok to run them off a Profile Clarus 1200 AMP?
Old Jan 12, 2003 | 06:03 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Infinity Kappa Or Aline Type R?
I would say to go with the type r's. If it were between Kappa perfects and type r's I would go with infinity. But out of those two, go with the type r's. What are you going to power them with?
Brian
Old Jan 12, 2003 | 06:07 PM
91GTA350's Avatar
Re: Re: Infinity Kappa Or Aline Type R?
Brian
I am thinking of powering them with a Profile Clarus 1200 Amp which runs at 300watts x 2 RMS
Old Jan 12, 2003 | 06:43 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I dont know if you have not looked at the JBL 600.1 but it pushes around 700watts and is aonly $195. The profile looks good and probably performs pretty good too but I have heard nothing but good things about the JBLs. My buddy has a 97 GMC ext cab with 2 alpine type r 10s and he is going to be pushing them with a JBL1200.1 next week. I will let you know how good it sounds. Right now he is pushing them with an alpine MRD 500.
Brian
Old Jan 12, 2003 | 06:48 PM
91GTA350's Avatar
I thought they were only 1 channel amps?
Also, my friend has a Clarus 800 pushing his 2 10" Polk Dx subs in his probe gt andd they sound great.
Old Jan 12, 2003 | 06:51 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
It is a one channel, but that doesnt meen that you can only run one sub off of it.
Old Jan 12, 2003 | 06:53 PM
91GTA350's Avatar
What would I have to do to run it to 2 subs? I bought My 91 GTA 350 with the wiring already installed. Its 8 gauge phoniex gold amp kit with everything i need already in the hatch. Im builinding a custom box for the hatch next week.
Old Jan 12, 2003 | 07:11 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
The only thing you do is hook up all the wires to the power output. I am not sure if you want to keep the 8 ga wire though. You might want to upgrade to 4 ga. And since you are looking at getting DVC subs there are a couple of options on how to wire them. I will try and find a good page for you to check out.
Brian
Old Jan 12, 2003 | 07:20 PM
91GTA350's Avatar
Thanks. Im still debating whether to go with The profile amp or the JBL. Also, the alpine type rs on ikesound.com are 4 ohm woofers. Will that make a hige impact with either amp? Im not looking for competition grade sound, just alot of bass for my music while im crusing.
Im also going to upgrade my head unit to A Pioneer Premier DEH-740 MP.
My current setup is a Sony Xplod 52x4 head uint with remote (A nice unit, but i want the pioneer screen for looks) , and 2 Soundstream Tarantula 6x9 150 Watt RMS Speakers. Im eventaully gona install custom kick panels and 6.5 inch component speakers, due to the fact my 4x6 rockford front speakers are blown.
Old Jan 12, 2003 | 07:36 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
If you are getting dual 4ohm speakers, you will either have a 4 ohm load(series) or a 1 ohm load(parallel) If the profile amp is not 1 ohm stable then it will shut off if you hook up the speakers at 1 ohm. But it is a 2 channel 2 ohm amp so you could use that one. In general you will get more power the lower the ohms just based on basic laws of resistance. Here is the page I was telling you about.
http://www.maaudio.com/techsupport/b...ubwoofers.html
There all kinds of things to look for and every amp and sub changes the game. It is kind of a pain, but it will pay off in the long run.
Brian
Old Jan 12, 2003 | 07:47 PM
91GTA350's Avatar
My friends dad is an electrical engineer, so I guess I'll ask him about that. I think im going to go with the Clarus 1200 amps since it runs a t 300 watts x2 at 4ohms. Im going to order them this week, by the tyime they come in my box should be nearly finished. Ill let you know how it goes and post some pics of the finished setup.
One more thing, do the infinity kappas run a 2ohms unlike the alpine type rs?
Old Jan 12, 2003 | 08:58 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
http://www.infinitysystems.com/carau...er=KAP&Cat=SUB
Old Jan 12, 2003 | 09:48 PM
mudaholic's Avatar
why are you not choosing the jbl amp? its better, period.
Old Jan 12, 2003 | 09:59 PM
White Ninja's Avatar
the clarus will send 450Wx2 @ 2ohms...
Old Jan 12, 2003 | 10:31 PM
mudaholic's Avatar
yet, for roughly the same price (bp1200.1) you get just under 1600 watts into 1-or 2-ohms...
Old Jan 12, 2003 | 10:53 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
not roughly the same price but $70 more, and about $200 more worth of power. JBL is the way to go. And it is like half the size.
Brian
Old Jan 13, 2003 | 05:40 PM
91GTA350's Avatar
I checked the specs and the jbl 1200 runs at only 600w x 1 at 4 ohms. If i split it into 2 channels, i would only ebe running 300 per speaker which is the same as the clarus?
Old Jan 13, 2003 | 06:01 PM
mudaholic's Avatar
no. you can't "split" a mono amp into two channels. what you do is wire the two subs onto one channel. what this does it halves (or doubles, depending on how you wire it) the impedance of the speakers. for example, if you have 2 4-ohm subs, you wire them together in parallel and you now have a 2-ohm load. now, the jbl is rated at 1200x1 into 2 ohms; fortunately for us, it is very underrated and actually puts out something like 1470 watts--pretty damn good for less than 300 bucks. so, you hook up both speakers to the amp, and they each get half of that--roughly 750 watts a piece. not at all bad, considering the price.
Old Jan 13, 2003 | 06:06 PM
91GTA350's Avatar
If i do this , will 750 watts per sub be too much for the infiniti kappa 12 subs? I would get the perfects. but my spending limit is $500.00
Old Jan 13, 2003 | 07:28 PM
mudaholic's Avatar
have you thought about getting a single sub, like the adire brahma? check it out here
Old Jan 13, 2003 | 07:31 PM
91GTA350's Avatar
i wanted to go with 2 12,s becuase im building a duel 12 custom enclosure. I have pretty much settled on 2 Infinity Kappa 12s dvc unless someone can recomend better subs around 125 each.
Old Jan 13, 2003 | 08:48 PM
91GTA350's Avatar
Tonights burning question must be, the jbl 600 or the jbl 1200 amp for 2 12inch infinti kjappa subs , (oir should i use 2 12"4ohm dvc type rs) Can i run both brands of subs at 2 ohms?
Old Jan 13, 2003 | 09:13 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I would go with the type r's. I think that you will get a good amount more thump out of them and they are really clean too. I would also go with the JBL 1200.1 just because that way you have room to grow. You can always turn down the gain on it and only push so many watts, the 600 can only go so high.
Brian
Old Jan 13, 2003 | 09:14 PM
82berlinetta350's Avatar
First thing, you cannot get 2 ohms with dual 4 ohm dvc subs. You can however get 2 ohms, if you run each sub from it's own amp. Therefore, I'd recommend 2 JBL 600's. As for the subs, it all depends on what you really want from the system. If you want serious spl numbers, go with the Alpine. As for overpowering the subs, don't be as concerned with that. It all depends on how high you run the gain, bassboost, and bass. If you run a conservative amount of each, you'll be fine. I'd also suggest getting a small sub crossover. You can get some for as low as 20 bucks.
Old Jan 13, 2003 | 09:19 PM
mudaholic's Avatar
jbl amps run stable down to 1 ohm. you can wire both those subs fine to any bp series jbl amp without a problem. or, you could pick up the 4-ohm SVC versions, since it will play marginally better at 2 ohms than at 1 ohm. and you dont need a crossover--its built in to the amp. buying 2 600.1s is stupid in this instance
Old Jan 13, 2003 | 09:24 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
agreed. If you have 2 dual 4ohm voice coils you can run them @4ohm or @1ohm. The JBL is 1ohm stable. I dont see the problem. I am not sure what ohm voice coils the infinities have though.
Brian
Old Jan 14, 2003 | 06:56 AM
91GTA350's Avatar
Thats why I dont want to buy the alpines. Im pretty sure that the infinities run at 2ohms.
Old Jan 14, 2003 | 02:16 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
There is nothing wrong with running @ 1ohm. The only time you might see a problem is if you have everything at full volume/gain/bass boost for 24hrs a day everyday. Then it might be a problem.
But if you dont want to do it, its your call. If you are wanting to spend around $125 on a 12 then check out these Kicker L5 12" woofers. They will kill both the type r's and the kappa's.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1950991246
Brian
Old Jan 14, 2003 | 02:59 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
get the alpine. they rock and are almost indestructable. dont buy a profile amp. i did and had to return it 3 times. kept breaking because they are crap. dont waste your money on them.
Old Jan 14, 2003 | 03:45 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Don't limit yourself to those two choices.
An Adire Shiva costs the same as those, and I think it's a higher quality driver. I haven't had the chance to audition one yet, but those subs typically get compared to MUCH more expensive, sound-quality oriented stuff like the JL W6s, etc. There are a lot of small speaker companies out there that are making fantastic stuff, but aren't as well known because they don't **** millions into advertising.
www.adireaudio.com
Old Jan 14, 2003 | 10:00 PM
burnouts4ever's Avatar
the jbl amp's are awesome and you can get earbleeding bass out of the 600.1 but i think the 1200.1 would be better.
Old Jan 15, 2003 | 09:00 PM
The reason I recommend getting 2 of the 600's, is that it will be much more of a reliable set up, if you run it at 2 ohms instead of 1. Running at 4 ohms would be ideal, but getting enough power at 4 ohms is hard. And the reason I mention the extra crossover, is because it allows you to have further control over the level the subs play at. I run one before the amp on my system. It really is just helpful in allowing you to fine tune the sub portion of the setup.
Old Jan 17, 2003 | 03:56 PM
91GTA350's Avatar
Will the JBL 1200.1 Amp msupply too much power to the infinity Kappa 12"subs? Would the 600.1 be a better choice? Also, whould I need a capacitor?
Old Jan 17, 2003 | 06:57 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I dont think you need a capacitor. The JBL 1200.1 will be too much, if the gain is all the way up. Just turn down the gain, bass boost, and bass and you will be fine. Then if you want it really loud turn some of them up a bit.
Brian
Old Jan 17, 2003 | 10:42 PM
91GTA350's Avatar
I would buy the 600.1 , but if i have to run it at 4 ohms, i will only be getting 150 watts per channel
Old Jan 17, 2003 | 11:31 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
with my experience with Infinity i think without a doubt they are the best subs anyone can buy be it kappa refference or perfect.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
