HX2's
Old Jan 27, 2003 | 07:47 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
HX2's
What kinda amp should I use for 2 Fosgate HX2 DVC's?
Old Jan 27, 2003 | 08:10 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
A Good Class D amp...
Old Jan 27, 2003 | 08:28 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
any specific brand or wattage i should look for
Old Feb 1, 2003 | 02:07 AM
onebadwagon's Avatar
power hx2's or punch hx2's?
i had two power hx2's wired up to 2 ohms on a bd1000, sounded good. then i put one down at 1 ohm on the same amp sounded really good, and hit very hard. just be careful, the box i had was too large, and i blew both subs, with no signs of distortion.
i was pushing roughly 1800rms into the one hx2 though.
if they are the punch hx2's a BD1000 is a great choice. for two power hx2's id check into the bd1500 or the 1050S
adam
Old Feb 1, 2003 | 10:57 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
thanks alot for the advise
Old Feb 20, 2003 | 11:34 AM
fbodyking's Avatar
Tony, did you ever figure out what you were going to do? Is it all straightened out?
Old Feb 20, 2003 | 11:44 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
well for now i just got a sony xplode 1200 watt amp, mainly because its stable down to 1 ohm and right now i dont have alot of money to put into the stereo, its all going into my 383 and suspension. As soon as i save up though I'll probably get the the bd1000 fosgate amp
Old Feb 20, 2003 | 12:07 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're going to run that sony at 1 ohm, make sure to keep it away from all flammable objects and to make sure you send in your warranty registration.
Old Feb 20, 2003 | 01:26 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
i bought it as an open item cuz it was cheap and just temporary it came with a 2 year warrany
Old Feb 21, 2003 | 07:41 AM
Jim85IROC's Avatar
It doesn't matter why you bought it, I'm just giving you some advice that you would be smart to listen to. We even had the damn sony training guys admit that their "1 ohm" stable amps can't take 1 ohm for long.
Old Feb 21, 2003 | 01:43 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
the box i have for the hatch has the 2 subs on the outsides and im going to mount the amp in the middle so you think that would be a good place for now? eventually id like to build an amp rack over the gas after after i get my new amp
86WS6_T/A
Car Audio
Aug 1, 2003 10:03 AM
NEEDforSPEED
Car Audio
Jun 15, 2002 08:05 PM
crows_camaro
Car Audio
Mar 25, 2001 08:05 PM
