Seperate vs single chamber for 2 12's
Old May 13, 2003 | 03:23 PM
Eric86TA's Avatar
Which is better for a ported box? Is it better to keep a ported box seperate from one side to the other? Is there a performance difference if you have on big chamber for two 12's and combine the port size into one single port?
Old May 13, 2003 | 06:16 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i believe both should be fine. the only problem with seperating is if you dont mae the boxes equal in size. also, if you're running stereo (which doesnt make much sense for subs...), you have to run two seperate chambers.
Old May 14, 2003 | 10:03 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
yup, he pretty much covered it. In my thirdgen boxes I usually provide shared chambers because it's difficult to get 2 equally sized chambers in such an odd box shape. If you do use separate chambers, in a sealed setup there's a little bit of room for a fudge factor. If you look at the low frequency roll-off of most subs in a setup with a system Q of .707 vs. .800 or even .900, you find that there really isn't a big difference, and the phasing isn't going to come into play either. Obviously it's better to have identical chamber sizes, but you can fudge it a little bit.
With a ported box though... you want them to stay identical in size.
Old May 14, 2003 | 10:12 AM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
Transmission: TH350
sharing the same box for two subs shouldn't be a problem. it will also be eassier to make sice you are not gonna be working with an everyday rectangular box.
Old May 15, 2003 | 03:24 AM
onebadwagon's Avatar
just remember, if the box is separated, and you blow a sub, you will still be at the correct airspace for the sub, if they share common air (i believe fosgate actually recommends this) then if one blows, it wont sound good at all.
adam
Old May 19, 2003 | 12:40 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
is ported much better than sealed for getting harder hits and nice deep bass?
Old May 19, 2003 | 02:18 PM
Jim85IROC's Avatar
harder hits? Yes. Deeper bass? No. Ultimately it depends on the sub too. Some are better suited for sealed, some ported.
Old May 20, 2003 | 10:35 AM
Polecat's Avatar
Usually ported boxes will be 'louder' with less power.
For seealed applications, we reccommend one woofer per chamber. because if you loose one driver, the other can see almost 'twice' the airspace, and on some, not good for the driver.
ported, you can do a common chamber and be fine...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
