hidden amp
Old May 23, 2003 | 11:52 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
hidden amp
wheres the best place to hide an amp where theres a good suplie of air flow? thanks alot!
Old May 24, 2003 | 12:54 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Spare tire well.
Old May 24, 2003 | 01:54 AM
onebadwagon's Avatar
screw it to the muffler.
adam
Old May 24, 2003 | 02:10 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
someone's been pretty negative in their last few posts....
anyway, try spare tire area or in the driver side compartment
Old May 24, 2003 | 02:12 AM
lmfao, camp3ro.
thanks for noticing.
Old May 24, 2003 | 06:30 AM
9177's Avatar
I took out the cardboard thing in the lock bock and put in some wood and mounted my amp to that.
Old May 24, 2003 | 07:34 AM
lockdude's Avatar
So did I.
Old May 24, 2003 | 08:09 AM
dsaint1347's Avatar
That is one ugly cat or dog.
Old May 24, 2003 | 01:58 PM
thanks for all the replys. Is there anywhere else I can put it. I keep to much junk in the driver side wheel well. and I still want to keep the spare tire and jack.
onebadwagon: is that a cat or dog!
Old May 24, 2003 | 02:59 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Put it in the "hole" between the taillights and the gas tank. Then get a carpeted board that covers the amp. That's what I'll do. You can keep some more junk down there and it will be hidden. I'll probably get my board on monday so expect pics next week.
/edit:
Old May 24, 2003 | 03:35 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Try right clicking the picture and selecting "save picture as"....check the filename for the answer!
Old May 24, 2003 | 03:55 PM
thats where I was going to put it but the nitrous bottle is going to be in the way! What about under the seat, is there a good amount of air flow there? thanks alot!
Old May 24, 2003 | 04:11 PM
Meat Curtains's Avatar
I thought it was a furby :lala:
Old May 24, 2003 | 04:23 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Under the seats you can run into some issues. One is that you'll have to run your speaker cables longer, which may or may not effect overall performance. Depending on the size of the amp it may also not cool properly. Of course you always have the option of running fans which will allow you to put the amp almost anywhere. There's a tech article on this site on how to install the amps into the back seat. If you go to the main TGO page, and on the left menu it will say tech articles. Go there and at the bottom will be the instructions. I recently did this type of an install with a PSone and was very happy with the result.
Old May 24, 2003 | 06:18 PM
thanks joezero, but when I fold down the seats the anchor for the 5 point hraness gose there(dont trust the stock ones still recovering from my wreck a year later!). What kind of fans are you talking about< the ones like in the coumputer. The most watts im runing is 300.
Old May 24, 2003 | 11:53 PM
that cat is a PIMP. just ask him, lol.
adam
Old May 25, 2003 | 01:10 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Yeah computer fans work. Any fan that runs on 12 volts is fine. So is the anchor for the harness connected to the back seat itself or to the body behind the back seat?
Old May 25, 2003 | 01:26 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That cat has some 'cool' blue eyes though.
I've had my amps under my seats for ~3 yrs and never had any problems.
One's a Pioneer 40x2, and the other is a Punch 100 DSM. They keep my tush warm to.
Old May 25, 2003 | 12:49 PM
joezero, the anchors are attached to the body behind the seats when they are folded down. I guess I could put it between the two anchor points, but will it over heat when i fold the seat back up.
AJ_92RS, I was thinking about puting there, its not that big of an amp.
Old May 25, 2003 | 02:22 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Here's the tech article. http://www-ec.njit.edu/~ljd8271/amplifiers.htm
What this guy did was put plexiglass over the top of the amps and used fans to cool it.
But if you have the back seat down a lot you may not need the fans. I did it a little differently because what I was mounting wasn't as deep so I didn't have to remove any of the foam backing, so I guess it depends on how big the amp is. I don't imagine it overheating with the back seat up on short trips like to the store or a friends house. But like the example above there's enough room to install a fan so you could leave the back seat up all the time.
Old May 25, 2003 | 02:34 PM
Thanks joezero, I was just reading that after my last post. I dont have that big of an amp, its about a 3rd of the size. but how whould you do that with a split seat.
Old May 25, 2003 | 05:50 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
The split seat is constructed in the same way, just with two pieces instead of one. So you would only cut apart one side.
Old May 25, 2003 | 10:26 PM
I want to mount both 5 point harness like this(www.ws6transam.org/harness.html). so that means i would have to put the amp in the middile of the seat, and that would render the split seat useless. i just cant think of any where else to put it! thanks for all the help.
Old May 25, 2003 | 11:30 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
This is where i put mine
Old May 25, 2003 | 11:32 PM
that old pheonix gold stuff is great, i used to have an m44 on my mids/highs.
adam
Old May 26, 2003 | 12:04 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Is it possible to mount it more to the left or right instead of centered with the seat? I've never used/installed a 5 point harness before, so I'm not sure if that can be done. But it seems that if it could be moved say 4-5" off center you might have enough space for your amp.
Here is another option. This is from smokingss' car. He was able to hide his cd changer and xbox below his amp rack. But I think it would be easy enough to build something like this and carptet it to match and just leave it empty on the top.
BTW, this is in a 4th gen so it may look a little different back there, but the concept is the same.
Old May 26, 2003 | 03:31 PM
byjoe I think I got it ! I think that is a perfect place to put it. and then I can mount my t-top bag on top of it. I just got to make sure the hacth well close when i put the t-tops in the bag. thanks for all the help.
Old May 26, 2003 | 09:46 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
If you don't use the storage area on the driver side in the trunk, an amp wouldn't be noticed there.
Old May 26, 2003 | 10:36 PM
I allready thought about that, but I keep to much junk in there. and I like to keep my spare on the other side, and the n.o.s. bottle in the trunk area. so im pretty much out of room. thanks for the idea.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
