How many 12's can you stick in the hatch?
Old Jun 17, 2003 | 03:09 AM
600HPBerli's Avatar
I want to try and build something to house 6 12's in my car. Any suggestions?
Old Jun 17, 2003 | 06:45 AM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
just take out the back seats
Old Jun 17, 2003 | 08:14 AM
Guest
Guest
Posts: n/a
i got 3 to fit in the back hatch hole thingy :-D
Old Jun 17, 2003 | 03:24 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
three sounds like the most, i have a jeep charokee for sale... you could fit 12 12s in the back of that thing
Old Jun 17, 2003 | 05:04 PM
admrlam's Avatar
I had 2 12's and 3 10's in the trunk simultaneously, in ported enclosures. Im sure if you played wiith the spacing of the amps (used where i had the 2250SX for more cu. ft.) you could get 5 or six 12's....
Pics are at www.geocities.com/admrlam/Bird.html
Old Jun 22, 2003 | 12:10 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i've got an idea of how to get maybe 5 or 6 but you'd have to build a podium for your amps if you want them in the back or mount them in the back seat i did that with an 84 of one of my friends with 6 computer fans under plexiglass to keep them cool when the seat was up. you could also build one like this for three more 12's
Old Jun 22, 2003 | 12:13 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
sorry about the double post
Attached Thumbnails How many 12's can you stick in the hatch?-shelf-box-2.jpg
Old Jun 22, 2003 | 02:35 PM
badrs91camaroky's Avatar
I got 4 kicker solo barics in the hatch.....im sure i could have fit 2 more easy, but i didnt have enough money to buy 6......hopefully in the future i will be adding 2 more.....i put my amps in the glove box in the hatch....and i took out the spare tire and i have 3 amps in there....im sure if u play with it u could fit tons of 12's back there!
Old Jun 22, 2003 | 04:16 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
If you have tons of extra money, you can always do an isoberik configuration with woofers. That way they require 1/2 of the box space.
Downside is that you have more woofers to run power too, and don't get the 3DB gain from having an extra woofer running. Good side of things is it cleans up the bass more, and makes it more accurate.
I am not familiar with setting up an Isoberik configuration where the box is ported to a specific freq. though. I am not sure how well it would work, but winISD shows a serious DB gain when running isoberik with a tuned port.
Heard from one guy who had 8 8"s setup in his rear hatch well, and hit over 145 DB too, (normal configuration) so I guess it depends on what you want to do.
Old Jun 28, 2003 | 09:39 AM
Cuno's Avatar
You could fit 8 to 10 of the 12" subs in a custom box in the rear. If you use something like the Alpine Type R subs which only require .75 cubic feet of space it is not difficult to do. I had 4 in my hatch and could have easily fit 4 more. 3 or 4 will fit in the rear well if you build the box correctly, than 4 to 6 will fit on top of the hump. Maybe more.
Old Jul 1, 2003 | 09:20 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
im taking the iroc to the stereo shop and throwing 6 12s in the car...when im crusing..ill be just listening to 3 when i compete all 6 will be going...
iroc2nv
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
ndndndnd
Sep 28, 2015 08:00 AM
