IROC stereo update #3
Old Jul 27, 2003 | 07:01 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In update #1 I showed the LCD housing construction which still isn't done yet. In #2 I showed my deck install. In this one, I'm going to show the progress of my DVD player install.
The plan is to install it where the center vents in the dash are.
Here's the dash after I cut the vent housing off:
Here's the flat panel cut to fit:
I cut a slit in the plastic for the lip of the cage to rest in. The top of the cage will be held in place with plumber's strapping:
Here's the dvd player mounted. The pic sucks but you get the idea:
The trim ring will need to be trimmed down so that the dashpad will fit. Most likely, the dash pad will need to be trimmed a little bit too. Once I get it all mounted, I'm going to make a dummy plate to cover the dvd player. If I can, I'm going to make it out of the piece I cut off, complete with stock vents. If not, I'll just make a flat plate.
The trim ring surrounding the dvd player will also be routed and have screw holes added so that it looks the same as the stock trim ring around the radio & heater controls.
Old Jul 28, 2003 | 04:38 PM
hrddrv's Avatar
Car: 86 TA
Engine: 305 Carbed. Mainly stock Not running
Transmission: stock
Looks good man. Can't wait to see it complete.
Old Jul 28, 2003 | 08:00 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Hey Jim Lookin real good, cant wait to see the finished product. Quick question, how hard is it to take a dash like that out of the car??? Im thinkin of replacing mine.
Old Jul 28, 2003 | 08:23 PM
MaineIrocer's Avatar
Car: 1986 Iroc-Z
Transmission: Automatic
Looks pretty sweet cant wait to see it with the screen and everything all togeather.....Great job
Old Jul 28, 2003 | 09:44 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
not bad i like it alot
Old Jul 29, 2003 | 08:27 AM
Jim85IROC's Avatar
I don't know yet. This is a different dash. The one in the car has a crack in it, so I decided to start with a different one.
Old Aug 11, 2003 | 08:38 PM
Jim85IROC's Avatar
Ok folks... here's some more progress. Tonight I bolted the dash pad to the dashboard so I could finish cutting down the trim plate. I also set the lcd housing into place for a pic, but it's not really in the right spot because the dash has to be cut for it to be recessed a little.
Once everything is finished, I'll cut the screw holes into the plate, as well as route the edges so that it'll match the trim ring around the radio & heater controls. Now I've got to get off my *** and finish the LCD housing.
Old Aug 11, 2003 | 09:37 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Looks good.
How much was that DVD player?
Old Aug 11, 2003 | 09:48 PM
Jim85IROC's Avatar
I got it through Crutchfield just as they were clearing out the remaining inventory. I got it for around $280, which was less than half of the original retail.
Old Aug 14, 2003 | 07:31 PM
Car: 1986 IROC-Z
Jim, that is lookin real good!!! :hail:
Old Aug 18, 2003 | 06:34 PM
IROCamaro87's Avatar
Car: 87 camaro
Engine: 5.0 TPI
Transmission: 700R
whoa, that is aweome... i was always thinking about doing something with those vents since my ac never works ( : now i know what...
Old Aug 29, 2003 | 02:20 PM
Jim85IROC's Avatar
The old dash is out.
Old Aug 30, 2003 | 04:15 AM
TrueBlue91RS's Avatar
Hey Jim, do you think it's possible to modify the dash the way you did it without removing it from the stock location?
As a sidenote, how hard was it to take that sucker out??
Old Aug 30, 2003 | 08:00 AM
Jim85IROC's Avatar
It would be entirely possible to modify it in place, although removing the box that sends the air from the heaterbox to those vents could have been pretty tough.
THe only reason I removed it was that there was a big crack right above the radio/heater pod that wasn't going to get covered up by the monitor.
Old Aug 30, 2003 | 03:12 PM
Scooby's Avatar
Car: 1990 Camaro
Engine: 305 TBI
Looks good
Old Sep 18, 2003 | 01:36 PM
GndPrx's Avatar
Looks good Jim.
I have those same 2 JVC pieces in my truck...absolutely love them.
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
hayesaw0210
Aug 23, 2015 11:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
