Looking for a new HO Alternator
Old Aug 20, 2003 | 12:51 AM
RallyRedTexan's Avatar
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
I'm in the market for a new alternator for my 92RS 305TBI A4. I was wanting something with some serious output to run my audio system. What are you guys running?
Old Aug 20, 2003 | 12:56 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Get a B4C alt bracket and run a 140 amp Caprice police alt.
Old Aug 20, 2003 | 04:03 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
check out a company named "powermaster" ,they make a direct drop-in alt that's rated at 140 amps.
Old Aug 21, 2003 | 02:19 AM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
i just called up a few local alternator shops and asked them if they carried them. most of them can build one. i got a 140 amp. i may go back and get a 180. mine seems to be struggling w/ all the power im running.
Old Aug 21, 2003 | 07:51 PM
napa dude's Avatar
Car: 1991 z/28
you can buy a 145amp alt from napa. direct replacement
Old Aug 21, 2003 | 10:41 PM
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
Thanks for all the replies guys. I made a few calls around and found a couple solutions. The NAPA one sounds like a winner as does the Caprice idea. I'm gonna look into both of those. Cheers for the help bros.
Old Aug 22, 2003 | 05:49 AM
9177's Avatar
Look on summitonline.com for their iceburg conversion. Had mone for over a year with about 1000 watt system and an ooptima yellow top and had no problems at all.
Old Aug 22, 2003 | 04:45 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Consider going to a one wire alternator if yours isn't already. That seems to eliminate the low reading on the gauge and the replacing of the alternator and battery every two years. I alos went to a 6 gauge cable from the alternator to the battery when I went to a 140 amp alternator.... After going to the one wire alternator I found out I no longer needed a 140 amp alternator. Of course now I'm going to be installing an 850 watt amp so we'll see if I have to move back up........
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
