breaking in subs
Old Nov 6, 2003 | 05:57 PM
Makaveli's Avatar
breaking in subs
how do you guys do it? kicker reccommends a 2 week break in period, is that at like low volume, regular volume, etc. how do you guys break in your subs? i thought it was like the first 30ish hours of play have it at normal listening volume, and after that let it rip.
Old Nov 7, 2003 | 08:00 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
put a cd in, hit play. Enjoy.
Old Nov 7, 2003 | 10:07 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Kicker recommends you break in the subs.
Check out http://kicker.com/images/manuals/Com...ManualV2_1.pdf near the bottom they tell you how they prefer they are broken in.
Pretty much set it up on a bench, slap a 50 watt+ amp on it and put input of certain hz (depending on sub) to the amp input then adjust the gain so the cone goes to X max. Let it sit over night playing with no box.
Or if you want to take the lower tech way:
Just play it for 1 to 2 weeks at low to med volume. Just don't blare it till it's broken in.
That's what kicker recommends.
I didn't break in my subs, but they were preown'd and the previous owner broke them in.
Old Nov 9, 2003 | 07:05 PM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
Thats a new one for me but Im gonna say
Old Nov 9, 2003 | 07:52 PM
Makaveli's Avatar
BS to what?
Old Nov 9, 2003 | 08:45 PM
Engine: 383 SBC
That was the first time I heard of the free air break in also.
I say just put in a cd and play it at low volume and don't crank the gains or bass boost up. Let them break in afor acouple hours then increase the volume a little and keep going that way.
Old Nov 10, 2003 | 07:20 AM
Car: 91 Firebird
Engine: 305 TBI
Originally posted by Makaveli
BS to what?
To breaking in a sub.
Old Nov 10, 2003 | 10:04 AM
Jim85IROC's Avatar
Good for them. That's probably because so many knuckle heads crank the snot out of it 10 seconds after they have the amp hooked up and blow them sky high. Once the sub begins to function, some of the matierals will losen up a tad, and can change the parameters (and sound quality) slightly. But whether you break it in by a specific method or just start playing music really makes no difference.
Old Nov 10, 2003 | 01:08 PM
Engine: 383 SBC
K, sorry was just stating something. I didn't mean to start a flame.
Old Nov 10, 2003 | 02:54 PM
Jim85IROC's Avatar
Who's flaming?
Old Nov 10, 2003 | 03:01 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
yeah breaking in a sub, isnt going to give you any kind of real performnace increase. Its mearly a period of time in which youre loosing up a stiff unused suspension, or "burning" off excess glue. give yourself time to get use to the sub, and give the sub time to get use to moving...dont want to blow your ears...or your sub...or both
Old Nov 10, 2003 | 03:27 PM
Engine: 383 SBC
No one yet, but you know how 1/4 of the posts go. Seems just like everyone is quick to add in after 2 opinions are set, which turns threads into flames.
I agree though just as long as you don't crank it up to the max right away it should be ok.
Old Nov 11, 2003 | 12:43 AM
Guest
Guest
Posts: n/a
its true you need to breaking in the subs. you want to heat up the voice coil and let it cool down so it doesn't short out.
when they make the subs there is like a glue around the coil and when you heat it up it kinda moves around but ones you get it to normal temp and cool it off it stops moveing and its less likely for you to short out the sub.
best way to break in the subs is run the GAIN on the amp about 1/4 way up and the bass at about middle on the head uint and play it as loud as you want as long as its CLEAN
thats how i do it and i haven't blown a sub yet .
you also sould break in AMP's as well. its just like breaking in a motor after a fresh rebuild
Old Nov 11, 2003 | 12:12 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
please tell me you're not serious about breaking in the amps.... and if you're gonna say wiring needs it too, its all over.....
Old Nov 11, 2003 | 04:00 PM
Guest
Guest
Posts: n/a
not the wires but the caps
Old Nov 11, 2003 | 05:10 PM
onebadwagon's Avatar
do you have to break in your car battery too? how about your box, is there a way to break in your speaker box?
adam
Old Nov 11, 2003 | 07:30 PM
Guest
Guest
Posts: n/a
adam
i have never heard of anyone breaking in a battery and the box its self you don't need to break in just the subs. you can break in the subs in or out of the box.
Old Nov 11, 2003 | 09:03 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
there is absolutely no need to break in an amp
Old Nov 11, 2003 | 09:15 PM
Guest
Guest
Posts: n/a
ok so your saying you would buy a brand new AMP and turn the gain up all the way and bass boost (you should never do that to start with) and play it as loud as you want? i have seen so many people blow an amp from doing that they blow out the power supply on the board.
Old Nov 12, 2003 | 12:22 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
turning your gain up all the way is stupid to begin with. i have yet to hear a good reason why you would. gain is not a volume ****. if your amp is setup correctly, you will not blow it. the reason why people doing this kill their amps is because its clipping, therefor its not properly installed. so i stand by my statement: there is no reason to break in an amplifier.
Old Nov 12, 2003 | 12:59 AM
Guest
Guest
Posts: n/a
as i said in my other post you should never turn the gain up all the way. and as for breaking in an AMP its really up to who owns the AMP. i always break in my amps and subs.
Old Nov 13, 2003 | 05:07 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I think if your subs coils heat up enough to melt ANYTHING you have serious audio system problems. Also , except for maybe a fan on some amps and the gain, bass *****, their is are moving parts in an amp. This is the reason why some amps last so long. This is also the reason why breaking in an amp Is a stupid thing to even think about.
Old Nov 13, 2003 | 06:52 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the reason why power supplies in amps die is because of playing a clipped signal too long (most commonly done by having gain up too high). an amp can put out double its rated power when it clips, stressing the power supply too much. if an amp is properly designed (most are) and it is properly installed and setup, extra fans are unneccesary (but a nice addition if its in an area of little air flow).
oh, and about the sub heat thing. if too much power is being sent to the sub, it can get hot. way too much power will fry it. but then again, you can kill a sub if its underpowered and setup wrong (no, underpowering alone wont kill it, but i probably just started a war with that comment and confused some people )
Old Dec 3, 2003 | 11:59 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
I had always thought of breaking in new subs like you would a new engine.
Yes it is designed to handle a certain amount of activity, but until things get in the proper "groove" there may be some trouble getting to that point.
Imagine a brand new engine, new oil, never run yet.
If you start that engine then stomp on the gas what will happen?
The idea is the same for subs and speakers in my opinion. There will be a noticable sound range difference with a new sub as opposed to a worked in sub.
Usually a newer sub's cone will seem stiffer and a bit harder to move, a worked in sub's voice coil will have been streched and lossened up to the point where the move easier manually. Usually a sub that has been worked in will produce a greater range of frequencies more noticibly.
A great example was my friend's Rockford 12 inch sub. When he first got it, it played, but t didn't hit much for highs or low, it was kinda punchy and that was about all.
As time went by, (weeks and months) the sub slowly gained more sound range and hit harder and harder.
Also you may notice if you take a new sub and put a high amount of power into it right away it is more likely to pop as it hits, while if you take the same sub once it has been used for a month and put the same power into it it will sound fine.
I do realise this does change with different product lines and different levels of quality.
Old Dec 3, 2003 | 12:13 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
lol Breaking in the subs? seems kinda odd so I just have one question... Why woulnt they do that at the factory? maybe they do but what happens, the sub sits for to long and the glue in the coil becomes hard and not so flexible there for doesnt take heat that well and burns up and wears down quicker? Am I thinking to hard? lol ummm I'm sure it shoulnt take like 30 days to break them in, maybe 5 hours seems resonable, just in case even just over a rumor, I would break them in for 5 hours before cranking them real loud, well I usually woulnt take them to the max after first installing them either o.O Just doesnt feel right, I would like adjust to it myself and listen for distortion and.. well yea...
Old Dec 4, 2003 | 12:14 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
I agree with you in most of that, and it does seem that newer subs don't seem to have to have that done as much or at all.
But, I emailed JL audio to see what they have to say.
here is the email...
Hi there,
Just a quick question. Is there any kind of a recommended work in period
for your subwoofers? If so what is it?
Thanks alot.
Chris Curiston
Hello Chris,
Well, you may hear the difference in the response of your system after about
around a week and half of use.
Enjoy
Ron Funk
Technical Support
JL Audio Inc.
e-mail: rfunk@.jlaudio.com
954-443-1100
Thanks for your interest in JL Audio.
Check out our website: WWW.JLAudio.com
I also emailed Rockford. Here is the email...
Recently you requested personal assistance from our on-line support
center. Below is a summary of your request and our response.
We will assume your issue has been resolved if we do not hear from you
within 48 hours.
Thank you for allowing us to be of service to you.
Subject
Working in a new sub
Discussion Thread
Response (Sean) - 12/04/2003 09:10 AM
Chris,
Thanks for contacting Rockford. We usually recommend a 24 hour break
in period. This should be plenty of time for the woofers. Hope this
helps.
Customer (Chris Curiston) - 12/03/2003 08:33 PM
Is there any kind of a recommended working in period or method for new
subs?
If so what is it?
Question Reference #031203-000053
Product: Subwoofers
Sub-Product: All Subwoofers
Category: Install/Troubleshoot
Contact Information: demicon@yahoo.com
Date Created: 12/03/2003 08:33 PM
Last Updated: 12/04/2003 09:10 AM
Status: Waiting
I am not trying to be a jerk here. Please don't think I am.
In my personal experience with 2 different Soundstream subs, 3 different kenwood subs, 2 pioneer subs, 3 Rockford subs, 1 earthquake sub, as well as information from friends who have participated in car audio competitions, in a variety of cars, trucks and vans, and in a variety of enclosure designs and types. It seems that a sub will not only perform better but it will usually last longer and handel a bit more abuse if it is givin a chance to move around for a while in whatever enclosure you make for it at a moderate level first before treating it like it has been there for years.
Again, it seems that the newer subs are not as needy in this case. My 2 pioneers didn't seem to care whether they were worked in or not. But even they had a difference in range ability after about a week of use.
Again, try taking a new sub and manually moving the cone. Then take the same sub a month or so later with normal use and try to manually move the cone. I can guarantee it will be easier to move. This tells me that something must be losening up. Perhaps streching out or something.
Keep in mind as well, all my examples had no changes done in any part of the stereo or its configuration during the "break in " period. The sub just began to respond better on the same music.
I hope this clears some stuff up. I hope this does not start an arguement. I am only trying to get my point across with some facts.
:hail:
Old Dec 4, 2003 | 05:31 PM
the only things that actually move/wear in the sub would be the voice coil leads, the spider and the surround.
besides those things, nothing "wears".
adam
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
