anyone ever got their 3rd gen metered?
Old Dec 15, 2003 | 12:06 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
just wondering what you guys hit on the SPL meter and what your setup is?
i dont have too much experience with these cars stereo wise so im trying to get a feel for how good they are as for as reproducing sound.
thanks for your time
Old Dec 15, 2003 | 01:56 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
last i tested it was about 6 months ago at 142.2 db. wasnt tuned yet and high amounts of distortion.
Old Dec 15, 2003 | 05:25 PM
raecar's Avatar
Car: 1987 GTA Trans Am
Engine: 5.7L
I hit 151.4 in my gta. I have 3 12in memphis with a power acoustick amp.
Old Dec 15, 2003 | 11:38 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
I had the bird done when i still had it bumped a 144.9 with 2 mtx audio thunder 4k's and a jensen 250 watt amp totally custom box. Looking at doing some audiobahns in the rs with a 1500 watt amp
Old Dec 16, 2003 | 05:23 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
how exactly did you pull that number with that equipment? It must not have been a legal score (was the mic on the dash)? What kind of mic was it?
Old Dec 16, 2003 | 08:29 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
umm..
Old Dec 16, 2003 | 09:16 AM
onebadwagon's Avatar
i think the mic was in the port, or somewhere like that,
he was just fishing for a good number.
adam
Old Dec 16, 2003 | 09:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I hit 141.1 with a pair of Oz 12" subs (they are SQ subs, not SPL subs) with the mic placed in accordance with IASCA rules. Mic placement makes an ENORMOUS difference on SPL, so if the mic was anywhere except where IASCA puts it, the numbers are impossible to compare.
I also got that number without tweaking my system for SPL. I measured it how I keep it day to day. This was before the whole "burping" thing came about too. I sustained that SPL for 15 seconds.
Old Dec 16, 2003 | 07:53 PM
92bird305tbi's Avatar
Car: 92 Firebird
Engine: 305 TBI
The best I done was a 146.9 with 2-12" DVC Pioneer and a 1100 watt Ample Audio amp.
Old Dec 16, 2003 | 08:54 PM
Car: 91 Camaro RS
Engine: TBI
THey put the mic just behind the dash about right above the shifter. I didnt know about where it was supposed to be till i got home and posted about it. So its probaly a little lower but the car did hit right its as much how the box is built as it is the equiptment just got some gear for the camaro now 900 watts
Old Dec 17, 2003 | 03:19 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
im trying to hit 155 legal (mic on the dash) with my setup when its installed which is very doable but it takes a lot of work and fiddling around with the setup.
Old Dec 17, 2003 | 02:18 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
if you hit 155, i might need some pointers once i get my sub...im trying to break 150 with 1 15" should be fun..i hear the new termpro mics are a bitch though
Old Dec 17, 2003 | 08:56 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
ya the new termpros are down like 6 db from last year...what setup are you planning on using to break 150?? If you throw a decent sub in a well planned wall with some decent power 150 is very doable. I think i could hit 160 with my subs if i gave them enough power but im trying to draw the line at 155 so i can save money
i hit 142.2 @ 27hz(certified termpro mic) out of the trunk with 1 15 and 400 watts in a big ported box. The roof, windows, and hood flexed a decent amount because the bass was so low
Old Dec 17, 2003 | 09:12 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
My old system I got a 140.6db with 2 american pro 12's and a cheap 600w rms amp, man did it sound horrible. My new system I should hit around 155dbs and still have unbelievable sq. I have 2-12in Adire Audio Brahmas and a 3000 watt rms US Amps.
Old Dec 18, 2003 | 03:42 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
you might have a bit of a hard time getting to 155 with the 12 inch brahmas. What enclosure are you putting them in?
good choice with the us amps...i just got rid of 4 vlx400s so i could get the amps for my camaro install. They were supposed to put out something like 5000wrms @1/4ohm each.
Old Dec 18, 2003 | 09:51 AM
Jim85IROC's Avatar
155 may be possible with enough power, and if he builds the box for maximum output at the transfer frequency of the car. With a box Q of .7, he should still still see high 140s, low 150s.
Old Dec 18, 2003 | 04:42 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
generally when you build an SPL box the Q of 0.7 isnt as disireable because you're going for more ouput and sound quality. 145 is certainly within reach, 150 might be a bit challenging, but 155 would be an accomplishment.
Old Dec 22, 2003 | 11:22 AM
Jim85IROC's Avatar
I do believe you just said the same thing I did.
Old Dec 27, 2003 | 03:55 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i hit a 155.3 with a 15" audiobahn alum15q and a kenwood 600 watt amp, in a custom made box,but it was in my truck, i have cracked my rear window once, not in the test, and my friend who lives 5 mile away, 1 mile as the crow flies could hear my start my car, you could hear it coming a good 5 minutes away if you know what to listen for.
i havn't gotten round to finishing my box for my bird, but when i get it together, it should be nasty
12.1d infinity perfect on the kenwood 600 watt amp
should rumble, can't wait to get that together and get it tested
Old Dec 27, 2003 | 07:21 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
that couldnt have been a legal score at the dash
Old Dec 28, 2003 | 11:29 AM
Car: 91 formula
Transmission: t5
why not ?? if you dotn watn to believe it thats fine i dont really feel like argueing, but it is waht i hit
it is a small extended cab toyota pickup
i had to get rid of it because it would hurt my ears after a bout 20 minutes of listening at normal volume, i had 3 layers of dyna mat extreme lining my whole cab and the side panels, doors and other parts of the truck still rattled
Old Dec 28, 2003 | 07:32 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i agree that it would be a loud setup, but at 155 most people cant stand sitting in the car you cant see and cant breathe most of the time. Ive owned the audiobahn aluminums and they didnt seem like much of a dedicated spl sub to me
what box did you have the sub in?
Old Dec 28, 2003 | 08:52 PM
raecar's Avatar
Engine: 5.7L
i belive u hit 155 db. My friends camaro hits 151.6 with two 10's and my other friend hits 158 plus with 3 12's in his camaro. same one's i have but diffent box and more amps than i do. but both cars have shops that gave them the stuff to go complete with. and i know they are legel and so is mine. you just can't tell how hard some thing is going to hit till u try it.
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
