Installing a CD/Mp3 player in the roof?
Old Feb 29, 2004 | 11:01 AM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
I want to put my CD/MP3 player in my TA, however I don't want to get rid of the original casette player, so I was thinking, maybe I could put it in the roof, in the center behind the mirror.
I am wondering if there's some kind of console or something like that which I could mount in the roof and then mount the player in that, instead of just fixing the player to the roof, which would be horribly ugly.
Or do you know any alternate locations to put a CD player?
Though I think if done right the roof might yield a very good looking result.
Old Feb 29, 2004 | 11:20 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
a cd player up there will look pretty big and oddly placed but it can be don. in my taurus i wanted to leave the faceplate the way it was from the factory and i had an under the dash unit installed. you cant even tell i have a cd player when you look in the windows. here is the kit i used to mount mine under the dash. it looks pretty slick to.http://www.crutchfield.com/S-gzncwq1...=0&cc=01&avf=N
Old Feb 29, 2004 | 11:28 AM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
thats crazy man, never knew there was an actual product for that.
Old Feb 29, 2004 | 11:40 AM
I dunno really where I could find room for that, anyone else that has two players in his TA?
Old Feb 29, 2004 | 12:57 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Man, I hope you didnt pay 24 dollars for that kit...that is a metra kit that costs no more than 12 to 15 bucks at any audio store.
Old Feb 29, 2004 | 08:19 PM
BirdsofPray's Avatar
Car: 1991 Z28
Do you still use cassettes? Otherwise, why don't you simply keep the stock cassette player in your garage or closet?
At any rate, if you finally decide to mount the player in an abnormal position - I'd like to see pics!
Old Feb 29, 2004 | 08:45 PM
nolanr0413's Avatar
Car: Trans am
what if u put it in the center console, maybe make it deeper and put in in there, have it facing straight up and down.
Old Mar 1, 2004 | 01:04 AM
Not really no, but the radio on that thing is really nice, and it looks really good where it is as well, plus the thing controlls the power-antenna.
I plan to use it for the radio and then the CD/MP3 player for playing discs.
Old Mar 1, 2004 | 06:46 AM
89RS-T's Avatar
solution
ok this is oe of my favorite i did it in my 89 rs bnecause i had a 7" tv in place of my radio. purchace a cd player with detachbale face! MOUNT THE UNIT A UNDER THE SEAT B IN THE COPMSOLE OR EVEN IN THE REAR IF PUTTING DISC IN IS NOT TO OFFTEN THE YOU VERY CARFULLY YOPU GET YOUR SELF A SOLDERING GUN AND ONE AT A TIME SOLDER TO THE UNIT AND THE RUN WIRES TO WHERE EVER AND SOLDER THEM TO THE FACE I MOUNTED MY FACE IN THE VISOR BUT IN DOING THIS BE VERY CAREFUL AND HEAT WRAP EACH WIRE LIKE YOU WOULD A FUSABLE LINK SO THE DONT TOUCH THATS THE SOLUTION B!
Old Mar 1, 2004 | 09:47 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Re: solution
huh? and no i did not pay 24 bucks for the under dash unit. i got it for 15 shipped i think. i just used crutchfield as a reference.
Old Mar 1, 2004 | 12:42 PM
Meatikis's Avatar
Car: '86 Z-28
Re: solution
Old Mar 1, 2004 | 02:53 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Re: solution
UNDERSTADNABLE NOT POST THIS IS AND MAKES IT MY BRIAN HURTING TO INTURPETED IT
Old Mar 1, 2004 | 03:36 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I don't think that would work so well, because extending the wires like that would end up with higher resistances and possibly cause the unit to not even work, but maybe it would, and that would be pretty cool. But to put in a cd you have to get to the cd player...
He means just extend the "wires" on the face of a detachable-face cd player. Then mount the actual player under your seat or wherever... then run the wires up to your visor and mount the face with the display and junk.... I don't see it working.
Old Mar 1, 2004 | 05:43 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
I had heard about that before, but the guy had to buy an extra face to put in the visor and keep the other face on the cd player because it wouldnt work right because of the resistance like someone mentioned. It looked pretty tight though.
Old Mar 1, 2004 | 06:23 PM
89RS-T's Avatar
pioneer deh-6500
i did it with a pioneer deh-6500 and mounted mine int the center console i personally took out the whole thing and fibergalssed a new one and made it so the radio would fit worked great and had no problem. Let me try to explain a littlme more in englis i guess...... ok take the face plate off of your radio.. you see the metal prongs on the face plate and in the unit you take individual wires to each and you go one at a time from face plate to unit and mount the fae plate like a tv in your visor...... it will not work if you forget to set the pin there a pins in the radio when the face plate is up kinda like the thing on your washer that makes it stop when you open the lid easy setup awesome outcome... wish i had photos i kick myself every time i taslk about it!!! as far as resistance im not sure the deh-6500 didnt give me and trouble so any more questions let me know! good luck
Old Mar 1, 2004 | 07:40 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Sounds like fun
I'd rather not have anything block the mirror
Old Mar 1, 2004 | 08:10 PM
Car: 1991 Z28
Re: Re: solution
Whoa, FyreLance, I didn't know you spoke pig latin! Definitely comes in handy sometimes....
Old Mar 1, 2004 | 08:13 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Re: Re: Re: solution
esya ita oseda
Old Mar 2, 2004 | 03:51 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
you could probably fit it in the console face up...i did this in my last car and it worked quite well. I set up the rear view faced down so that i could see the deck. The only problem you may run into is the cd player might skip a bit more than usual as some manufacturers dont recommend mounting on any sort of angle, but my alpine was fine.
you could also try mounting it in the glovebox if you have one.
Old Mar 2, 2004 | 07:04 AM
89RS-T's Avatar
if you put the face in teh visor and the unit in the console then you wont have this huge thing on your roof and it wont block your mirrior. and it will be one that not many people have and thevies will not be a problem
Old Mar 3, 2004 | 01:15 AM
ScrapMaker's Avatar
how do you use your rear view mirror if its sideways like that seems kinda silly...
Old Mar 3, 2004 | 03:43 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i had a subwall in at the time so i couldnt see anything anyway
Old Mar 3, 2004 | 11:52 PM
ScrapMaker's Avatar
ah that makes a lot more sense...
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:52 PM
