My stock casette player keeps spitting out tapes
Old Mar 7, 2004 | 01:38 PM
HisDivineShadow's Avatar
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
I dunno why, I've tried many a old tapes I've found, everytime I put one in it spits it out again, dunno why it does this.
Old Mar 7, 2004 | 01:59 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Broken belt inside cass. deck, very common, easy repair!
Old Mar 8, 2004 | 07:54 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Like Dutch-Bird said, it’s probably a broken or slipping belt. Take a look, if its not post back, there is a couple of other things to look for to. But the broken/slipping belt would be the most common.
Old Mar 8, 2004 | 08:29 AM
This is where exactly? Near the place where you insert the tape?
Old Mar 8, 2004 | 11:00 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Your have to CAREFULLY take it apart and get to the bottom of the tape mechanism.
Old Mar 8, 2004 | 11:11 AM
Ok, lessee here... hammer, hammer... ah, here we go...
Old Mar 8, 2004 | 11:41 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
Hammer is good.
Crowbar, heavy pliers, hack-saw.
heck just drag in the jaws of life.
heh heh
Old Mar 8, 2004 | 03:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Keep the old belt; bring it to the store to use as a guide for the replacement belt. Try not to let them sell you on one that's shorter or thicker than your old snapped one. They'll say "oh it's shorter because the old belt stretched"- uh-uh.
If you get a shorter or thicker belt, you'll actually slow down the cassette motor, and your tapes will play in slow-motion! (Been there; done that...) A thicker belt will have less stretch to it then a thinner belt- and a thicker one might not fit the pullies.
Old Mar 9, 2004 | 07:39 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
It’s not at all uncommon for a belt that length to stretch 5-10% or more. Especially one this old. I would call the place first and see if they use a PRB (Projector Recorder Belt Co.) cross-reference book. It should have the belt for your stock HU in it. It will show one of there part # for a belt that is the same length and width as original.
Old Mar 9, 2004 | 07:51 AM
I certainly won't be spending any money on it, if I can't fix it myself I'll just take out this player and install my mp3 player there instead.
jaridjohn
Jul 8, 2024 03:49 PM
Genopsyde
Oct 7, 2015 08:35 PM
Zachattack0925
Aug 12, 2015 09:52 PM
