cant decide between these subs
Old Mar 18, 2004 | 10:31 PM
peruvious's Avatar
Car: 1991 Z28
Transmission: t-5
right now i have two infinity references. they sound great but i think i want a little more. so here is whati have found
2 JL W3v2
2 Crossfires
2 Alpine Type R
or stay with my infinitys
(all 12")
i have a concept 1252 amp which will be powering what i set up. the amp over powers my infinitys as it is now. what do you all think will be better
Old Mar 18, 2004 | 11:10 PM
shortyjmg's Avatar
Car: 86 sport coup
Engine: 5.0
get a kicker solo L5,L7 they will hit very hard i Have a 15" with a 1100 watt phoenix amp it goes very lound. alpine type R hits well to
Old Mar 18, 2004 | 11:34 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
2 JL W3v2
And Xtant amp, you can't go wrong, it will shake your bones loose.
Old Mar 19, 2004 | 02:08 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Re: cant decide between these subs
2 JL W3v2
2 Crossfires
2 Alpine Type R
(all 12")
your amp puts out 400wrms @4ohms mono so you will want something that you can wire to that impedence.
there are a lot of people in the same boat as you for buying subs. You need something that works in a small box with a good mix of SPL/SQ and works well with minimal power.
these will all work for you:
JL w3s
alpine type rs
infinity perfects
1 adire shiva (only available in 8 ohm DVC)
kicker L5s (i think the L7 would work better with more power)
Elemental Designs e12Kx
Digital Designs 2500 series
if it were me i would go with either the adire sub, ED, or DD for two reasons: being unique (not many people around will have these brands), and it may deter thieves from stealing your setup if they've never heard of it
Old Mar 19, 2004 | 11:17 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
my vote! Price cant be beat. Whats it like $125?
not the best as far as looks but who cares!
A VERY good sub. wire it for a 4 ohm load.
Also ED has the k line, they have a 12 for $85 if im correct.
Old Mar 19, 2004 | 04:56 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
ya the shiva was on for $125 the last time i checked...i had a single tempest about a year ago and it was excellent. put up a 142.2 @27hz legal with about 400 watts
Old Mar 19, 2004 | 09:53 PM
br()bert's Avatar
Car: 85 firebird
Im making a fiberglass box for my car. Im thinking of a shiva.
1. It doesnt need 1000's of watts to sound good so the two amps i have now can stay. (they are 400 rms(component amp)( and 600 rms bridged, used for sub)
2. Doesnt cost hundreds and sounds very good.
Old Mar 20, 2004 | 05:17 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
600 watts will be plenty for a shiva...just make sure you have a subsonic filter on it so it doesnt bottom out. My tempest finally blew after about 10 months or hard abuse with 400 watts in huge low tuned boxes. It blew as i was playing a 20 hz test tone
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
