Capacitor wiring
Old Mar 20, 2004 | 02:36 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Capacitor wiring
I bought a used capacitor off ebay and it did not come with any wiring instructions. Can anyone give me some directions, diagrams, and/or tips for wiring it up?
Old Mar 20, 2004 | 04:10 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
batt + to cap + then cap + to amp +
Ground from car to cap - then cap - to amp - (ground)
Old Mar 20, 2004 | 05:01 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Basically all mine told me to do when i got it, was to cut the batt to amp wire and put the positive terminal of the cap on that wire. Then it had a seperate ground for itself.
Old Mar 20, 2004 | 08:09 PM
Axle/Gears: 4.10
My capacitor has a digital readout on it and I tried the wiring you just described but then the readout was on constantly, is that what I want?
Old Mar 20, 2004 | 10:02 PM
br()bert's Avatar
Car: 85 firebird
Does your cap have a turn on wire or connection screw?
Old Mar 20, 2004 | 10:12 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yep, run a seperate wire from the cap to ground dist block or frame (make sure all grounds are connected to the frame at 1 spot)
Run cap display turn on wire to remote or amp) turn on from deck.
You'll want as short a wire as posible between the amp and cap.
Old Mar 20, 2004 | 10:52 PM
In my opinion, you should take all that digital stuff off, and just use the basice capaciter, my experience has been that they are just a PITA
Old Mar 21, 2004 | 12:05 AM
Axle/Gears: 4.10
ok, ill look for a place for a turn on wire tomorrow
Old Mar 21, 2004 | 05:50 PM
TheNutzZ28's Avatar
Car: 89Iroc Vert, 86 Iroc/Z28
Engine: 383carb, 350 TBI
Transmission: Th350, 700R4
Axle/Gears: 3.23 posi disk, 3.42
Cool, I just got a used capaciter too, nice to see that my idea of wiring it up was right, thanks for starting the thread
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
