new speakers = big time rattles
Old Apr 7, 2004 | 08:24 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
got some new 6x9s for the rear, and got them installed, now all i hear is rattles thought out the car when they are on
the part that i dont get is that i put 2-3 layers of dynamat extreme behind the speakrs and that whole inside of the quarters
there is something uder the car that rattles also, and i cant figure it out, anyone get any ideas how to get rid of the rattles ?
kinda sounds a civic with a box in the back, all it does is rattle.
any ideas ?
Old Apr 7, 2004 | 09:47 AM
CaysE's Avatar
Check the door jamb vents, they're a big culprit when installing new 6x9s.
Old Apr 7, 2004 | 12:30 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
you put the dynamat behind the soeakers but did you put any between the metal plate the speakers mount to and the body of the car? This is an area that rattled the most on my car.
Old Apr 7, 2004 | 10:14 PM
86whitetransam's Avatar
Car: 1986 Trans Am
Transmission: 700r4 auto
i had the same problem after i installed alpine 6*9's in my t/a i tried every dam thing to stop them i got alot stoped then i just got pissed and put them in 6*9 cheap boxes you get at walmart and just put plexiglass over the holes to cover them up then i got alot more bass to because they were sealed
Old Jun 13, 2004 | 04:38 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I too have the problem with the door jamb vents... what can be done to stop the squeaks?!
Old Jun 13, 2004 | 05:27 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
take them out
Old Jun 13, 2004 | 06:08 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Originally posted by 1986CamaroSC
take them out
But that looks like ***! Is there an alternative?
Old Jun 13, 2004 | 08:57 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
You simply have to tighten everything up.
Anything loose needs to be fastened together. Any contact surfaces have to be dampened with a piece of rubber or cork.
Use you creativity, imagination and materials at hand for this.
I've eliminated rattles from cars by dismantling everything and re-assembling it in a way that would not allow rattles.
Just look at some of the newer cars to get some ideas, they are put together much better for systems. Most newer luxury cars sound fine without dynamat or anything else to help improve sound.
The vents are a part of the interior ventalation system, but you could seal them up with RTV or find a way to keep them from rattling.
Another solution would be to use 6.5"s in kickpanels and power them from an amp, loose the 6x9"s, since the location sucks anyways. A small sub in the pit will fill in the lows.
In my T/A, I mounted the 6x9"s in the rear pit cover, it sounded excellent and I had no troubles with rattles. I tried to mount them in sails one last time after I bought new speakers and an amp, but I didn't sound any good, I kept them in the rear. The glass allows much better bass reflection than the sail panels.......yes, you'd be surprized how much bass you can get from 6x9"s! I'd still recomend a sub, I put mine in the back seat. 2 12"s w/ a JL 500/1.....plenty of low end....although this opened up a whole new can of rattles. more audible from the outside than the inside.
Old Jun 13, 2004 | 09:14 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
third brake light rattled like a b1tch on my car.... same with the t-tops.... and make sure ALL the plastic interior parts are fastened together snugly,,,, dont make them tooo tight tho... you may crack or brake something like i did lol.... just my 2 cents
Old Jun 15, 2004 | 07:51 PM
CaysE's Avatar
Best way to keep those door jamb vents from rattling.
Old Jun 26, 2004 | 10:14 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
JB Weld, Duct Tape, and Zipties.
Old Jun 27, 2004 | 07:58 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
why do the stock 6x9's locations suck?i think that they are a perfect placement because they are centered in the car and are right in line with your ears... how would placement in the trunk in stead make for good listening when the speakers would sound like they are far away.... yea the acoustics might be better in the back for bass but i dont think in gonna go cut my kick panels and re-locate my 6x9s...imo stock location couldnt be better... if you need bass u deff need a sub(s) dont bother moving the speaker locations... and the rattle under the car is prob your exhaust system.... mine rattles when at a certain rpm... just wedge some radiator hose between something and your exhaust..... and there ya go problem solved... for that any way....also check out your windows .... because they rattle inside some times and its a b1tch to take all that door stuff off just for a rattle .... good luck man ....
Old Jun 27, 2004 | 03:08 PM
onebadwagon's Avatar
when you go to a concert, do you stand right next to the speakers?
you generally want your sound coming from in front of you, barring dvd movies or the like.
the front stage is what it's ALL about.
put some decent components in some kick panels, quit wasting your energy trying to get sound from the sails.
f body's in my experience sound like butthole with the factory speaker placement, flat and tinny up front, and hollow and unresponsive right next to your ears.
that's not a good combo.
adam
Old Jun 27, 2004 | 06:49 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
mmm imo i cant tell a diff.... maybe my ears are messed up oh welll as long as it doesnt rattle and sounds good to me i can deal with it and spend more time making my car faster
Old Jun 27, 2004 | 08:13 PM
well, if you can't hear a difference, then keep on rocking, it's only worth it if it makes a difference to YOU, so party on man.
adam
Old Jun 28, 2004 | 12:11 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
right on
Old Jul 1, 2004 | 08:41 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
89lsc
Aug 14, 2015 04:58 PM
mustangman65_79
Aug 8, 2015 12:07 PM
