when wiring tweeters...
Old Apr 20, 2004 | 08:19 PM
ratedrookie's Avatar
They come with tiny capacitors to block low frequencies. Does one wire these capicitors in line with the positive or negative wire or does it not make a difference?
Old Apr 20, 2004 | 08:46 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
wiring
it is designed to filter high out put signals from damaging the tweeter wich runs through the positive side of the speaker
Old Apr 21, 2004 | 01:09 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
Re: wiring
true story
Old Apr 21, 2004 | 07:13 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
It makes absolutely no difference which wire you put it on, it’s just a series circuit.
Old Apr 21, 2004 | 12:30 PM
robsgta's Avatar
tweeter??
well I would like to know where you got your info from??series circuit?? its a resistor..
Old Apr 21, 2004 | 12:42 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
what those capacitors do is filter the the lower frequencies,i.e bass and midrange. in other words it's a crossover. the cone on a tweeter is designed not to move much because it doesn't need to in reproducing high frequencies. if you were to connect a tweeter to an amplifierwithout the cap or a passive crossover , it would not live long at all.this is also why you want to block the high frequencies to a sub . it is designed to reproduce the low frequencies and running a sub full range will detract from that.the smaller a speaker is , the less it can reproduce lower frequencies but the better it will reproduce highs.also, it is best to always put the cap in series on the positive side. i realize that the amplifier puts out an ac (alternating current) signal but look at the passive crossovers, you 'll see the cap on the positive side. hope this clears this all up for ya.
Old Apr 21, 2004 | 01:39 PM
robsgta's Avatar
tweeter wiring
First of all it is not a capacitor a capacitor stores power in a dry cell trust me I have 2 of them and each one stores 1000 watts.
a resistor ie; resists certain frequency's from entering through the positive side of a tweet. and yes a resisitor does try and act like a cross over but it really cant do a good a job as a cross over or an amp set on high(that has a built in cross over). when a resistor burns up you wont know it and guess what go's next ???the speaker
Old Apr 21, 2004 | 02:00 PM
badjuju342's Avatar
Engine: ls1
well ,ok ,i've been installing professionally since 1984 and these are called capacitors. the power cap you describe is a polarized capacitor, there is a positive terminal and a ground terminal. if you connect it backwards , you gonna see a lot of smoke and a pop and a whole lotta cap innards.the capacitors used in the tweeter crossovers are non -polarized , there isn't a positive or negative terminal so you can't get it backwards. once again ,the amplifier signal is an alternating current ,it changes polarity so you couldn't use a polarized capacitor. the power caps you described are storage modules to compensate for brief peaks of energy (a hard loud bass note) so the amplifier is not as prone to "clip"(cut the top off of a sine wave). a resistor does NOT filter frequencies, it changes the resistance(ohms) that that amplifier output "sees". also ya might notice some manufacturers put a light bulb in the passive crossover , that is used to absorb the dc current that an amplifier puts out if clipping.the dc voltage will heat up the voice coil and burn it in half.this is why an amp that doesn't have enough output to do what you want it to do will burn a speaker up just as fast as an amp that is too large for for speaker's rms (root mean square) rating will.but hey what do i know? i've only been an professional installer for 20 years and am MECP certified first class.
Old Apr 21, 2004 | 02:18 PM
learsieglerZ'83's Avatar
Car: 1983 Z28
Transmission: 5 speed
yes it is a capacitor, no its not the same as the ones you hook up to "help" your system out better. crossovers consist of caps, resistors and inductors. heres a little bit of an article on how to build one...http://www.speakerbuilder.net/web_fi...xo/xoconst.htm
caps store watts??? since when?
Old Apr 21, 2004 | 02:42 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: tweeter wiring
What is this, see how wrong we can be?
I've read a couple of your post, you just keep on making me laugh. Try and do some reading. You couldn't be more wrong.
IT's not a resistor, it's a capacitor. And when you put a capacitor (Aka Base Blocker) on a tweeter, it IS a series circuit, or your doing it wrong. And it makes NO difference which wire you put it on.
Old Apr 21, 2004 | 03:15 PM
badjuju342's Avatar
Engine: ls1
absolutely correct, an capacitor does not store watts. the one thousand watts you see on the that cap is a generalized reference(and inaccurate) for what size amplifier it's designed to work. a .5 farad is made to be used for a smaller amp ,a 1.0 for a larger amp,1.5 for an even larger amp.
Old Apr 21, 2004 | 03:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Jesus christ.
This is quite possibly the dumbest thread I've ever read in the car audio forum, and considering the massive amount of stupidity I see on a daily basis, that's a huge statement.
Some of you guys should learn how to knit and stay the hell away from electricity.
Old Apr 21, 2004 | 03:26 PM
badjuju342's Avatar
Engine: ls1
geez jim , why don't you tell us how you really feel about this thread
Old Apr 21, 2004 | 03:58 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Originally posted by Jim85IROC
Jesus christ.
:yourock:
Old Apr 21, 2004 | 07:03 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
jim summed up everything i was gonna say. but he was more blunt
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
