JL Audio 1000 Watt Digital Amp
Is it worth $700
for this amp heres the specs
Rated Power:
1000 W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio*:
>95dB below rated power
Frequency Response:
5 Hz-500 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
19.7"L x 9.25"W x 2.36"H
(500 mm x 235 mm x 60 mm)
Features:
Differential-Balanced Input Topology:
(1 pair of inputs)
On-board Crossover:
fully-variable (40-200 Hz),
selectable-slope LP (12 or 24 dB per octave)
Preamp Output:
2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ:
parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter:
fully-variable 24dB/octave from 15-60 Hz
Output Polarity Reversal:
switch permits instant output polarity reversal
Dual mono speaker output connections:
accept up to 8ga. wire
+12V and Ground connections:
accept 4ga. wire (required)
for this amp heres the specsJL Audio 1000 Watt Digital Amp
Rated Power:
(11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio*:
Frequency Response:
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
to 800mV-8V RMS
Dimensions:
Features:
(1 pair of inputs)
On-board Crossover:
Preamp Output:
Bass EQ:
Infrasonic Filter:
Car: 83 z28
Engine: 300hp 355
some people swear by JL amps and say they're worth every penny. Personally i think they're built quite well and have decent specs but certainly arent worth the difference you pay over other quality brands such as JBL, autotek, dei, viper, orion etc
if you want a quality amp you'll get one with this amp but if you're looking for the best bang for your buck i would look elsewhere
Car: 83 z28
Engine: 300hp 355
Originally posted by NEEDAZ
I can’t find my paper work on that amp.
Is it a full digital amp or just a Class-D amp?
They’re not the same.
Car: 1983 Z28
Transmission: 5 speed
not to completly hyjack this thread or anything but.....what are some of the purely digital amps out there??? dident infinity have some a couple years ago?
Car: 83 z28
Engine: 300hp 355
this thread had some good info on class d amps if you're interested https://www.thirdgen.org/techbb2/sho...=class+digital
Car: 89 IROC-Z
Engine: 355 TPI
They’re a little off on some small details, but a lot of good info in that thread. But they didn’t even mention Class-G/Class-H, some of the “funner” ones to work on, but not often used in the mobile world.
And even though the “digital” Class-D amps aren’t what you would consider digital, when most of the manufactures are calling them “Digital Class-D” or “Full Digital Class-D”, it starts to stick and become the nomenclature. But all that’s about it where the conversion to PWM takes place.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I always figured they made those amps and sold them at that price for the guys running the W7's since they have like a 3 ohm or 1.5 ohm coil (I forget which). I figured it was a way JL could pretty much force them into buying an expensive amp off them as well.
Car: 83 z28
Engine: 300hp 355
Engine: 383 SBC
I know a friend who has a 13.5" running it down to 0.75 ohm final and JL said they don't recommend it for everyday apps only comp with their 1000/1. Doesn't help that mark up is so much on stuff too. The same guy managed to get the 13.5" W7 for 200 bucks from JL cause he worked for an audio shop and could order stuff at the actual manufactering price or lower.
You might check around on ebay for them. I know sometimes you can get them cheaper.
Another friend (doesn't work there) who bought a 12" W7 from the same audio shop managed to get a 1000/1 for around 500ish brand new.
raymondandretti
Sep 27, 2015 06:43 PM
