Can you turn a DVC sub into an SVC?
Old Jun 5, 2004 | 10:18 AM
85_ZED28's Avatar
Car: '85 Z28
like the title says, Can you turn a DVC sub into an SVC?
thanks
Old Jun 5, 2004 | 11:59 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
wire the two coils in parallel. Voila. One coil with 1/2 the resistance of each of the two.
Old Jun 5, 2004 | 09:36 PM
CaysE's Avatar
Voila indeed!
Old Jun 6, 2004 | 01:17 AM
Chimera's Avatar
also you should check the spec's on your sub as well as the amp your running it with . I ran in to problems doing this set up , my amp wasn't 2ohm stable while it worked underload the amp would shut down and reboot ect......
Old Jun 7, 2004 | 04:33 PM
85_ZED28's Avatar
Car: '85 Z28
actually i want to run the everything at 4 ohms. sorry i'm a rookie!
Old Jun 8, 2004 | 07:11 AM
Jim85IROC's Avatar
if it's dual 4-ohm coils, you can't get a single 4 ohm load out of it. You get 2 ohms or 8 ohms.
Old Jun 8, 2004 | 09:40 PM
85_ZED28's Avatar
Car: '85 Z28
ok, thanks that was what i was looking for
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
