question about sub boxes
Old Jun 10, 2004 | 10:46 PM
Mudd8227's Avatar
I like the sub boxes that you guys have put in the rear well. The only question is, what do you do with the T-tops? I have a pair of 10" subs i wanna put back there, but I don't wanna give up my T-Top storage. Any sugesstions?
Old Jun 11, 2004 | 12:27 AM
onebadwagon's Avatar
put them in the backseat.
Old Jun 11, 2004 | 08:55 AM
Mudd8227's Avatar
you mean take the rear seat right out?
Old Jun 11, 2004 | 09:02 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Nah, some people just set them on the back seat.
Some people tailor their boxes so that they can still "strap them in".
I personally like this alternative (this is my fourth-gen), if someone adapted this idea for thirdgens it would probably be a good seller. The t-tops fit in that notch that you see cut out in the front of the box.
Old Jun 11, 2004 | 01:52 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
I used to wrap my roofs in a blanket then put them on my back seat or in the rear deck area... but now that I finally have a bag.. here is what I have done..
Old Jun 12, 2004 | 05:52 AM
Gord's Avatar
FyreLance, I really love the way that looks, plus it's functional , awsome job
Old Jun 12, 2004 | 09:08 AM
FyreLance's Avatar
Thanks man, I had the guy from SubThump.com build it, he did an awesome job and built it to specs, it's well worth the money. I've been very happy with it and it's high quality.
Old Jun 15, 2004 | 08:53 AM
LaxStreetRacer's Avatar
Car: 91 Z28
Just remeber that if you must have your tops in the car when u have em off that if you dont find a way to secure them real tight or keep em separated thos things are probably gonna add a lot to the 100 or so rattles you will probably have anyways. Depending on how much room you have back there your might be abble to fabricate some kind of mounting system where they work just like on the car, each has a thin slot on 1 end where the glass slips in then on the other end a brace on each side with the holes drilled so the prongs on the side of the tops can be used to lock it right in place. Just my 0.2, havent had a ttop car in a while but when i did i just left em laying on the lawn.
Old Jun 15, 2004 | 12:16 PM
Jose'sRedTA's Avatar
Car: 87' Red TA w/ 92k miles
You can build a box like I did for the lower portion of the well...depending on the amount of air your subs need...mine being .4 - .7....but I can still use my t-top bag with my setup.
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
