wheres the antenna fuse?
Old Aug 24, 2004 | 01:14 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I changed the power antenna today, and on the prosses I accidentally crossed the wires. Now the new antenna doesnt do nothing & I cant find the fuse for my life. does anyone knows where it is?
Old Aug 24, 2004 | 01:20 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There are only so many fuses in the fuse box. Pull them one at a time until you find the blown one.
Old Aug 24, 2004 | 01:33 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I did & there is no blown fuse. It has to be in another place.
Old Aug 24, 2004 | 01:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The power antenna runs off the ACC fuse in the fuse box.
Old Aug 24, 2004 | 01:50 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
The ACC fuse is one of those metal ones on the corner, right?
Old Aug 24, 2004 | 03:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's a blade fuse just like all the rest.
Old Aug 24, 2004 | 05:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What year is your car? You might have cooked the relay under the dash. Just a thought!!!!!!!!!
Old Aug 24, 2004 | 05:50 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Its an 88. Where would I find this relay.
What hapened is that like a dumb *** I cut all 3 cables at the same time & I saw a little spark. when I finished the install the antenna dosnt do nothing. I know it was working before cause I could hear the old motor spin. now there is no power.
Old Aug 24, 2004 | 06:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is located under the dash on the passenger side. It is a little metal thing that looks about like this.
Old Aug 26, 2004 | 12:55 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Went to GM & got the relay form them the # is 22535475 and is called "RELAY ASM-RADIO".
Still dont know if its the right part or not, but Ill keep you posted.
Should be able to open the dash tonight or tomorow.
3rd gen money
Oct 11, 2019 09:57 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
