Opinions on Genesis 5-channel amp.
http://www.genesiscaraudio.net/amps/5ch/index.html
Any of you guys got any experience of this amp or opinions of it?
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Originally posted by shortyjmg
what would you want a 5-channel amp for dvd in the car?
i have heard of them dont know anything bad about them.
Equal power to the four main channels and then one extra amp for the sub. Makes sense to me!
Car: 2000 Trans Am WS6 (Black)
looks like a nice amp... but I wonder why they don't ever make these amps with 100+ watts @ 4 ohms per channel... thats why I haven't bought one of these combo amps... the subwoofer output seems fine, but it would be lacking elsewhere... 40watts IMO, doesn't seem like quite enough, but it all depends on what kind of speakers you are running, and what kind of filters you are using as well...
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have a 5 channel eclipse amp and I hate it. Most 5 channel amps just don't have enough power for the subs. If you're running a pair of 8" subs then fine, but if you want to push a W6V2 or a pair of them, you're going to want a lot more power.
For the same money or less you can get a solid 2 channel amp for your fronts, a stout sub amp, and you can always run your rears off of deck power. If you insist on amping your rear speakers, look for a 4x50 watt amp and a sub amp. Your investment will still be around the same as it would be for the 5 channel amp.
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
ya your better off getting sepperate amps each designed for sepperate speakers... 40 watts isnt all that much more then your head unit prolly gives you. Granted itll sound better of course but still....Its your choice...
Nate
Nate
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Nate
Nate
The reason I would stay away from a multi purpose amp is because I feel that you shouldn't skimp out on powering your subs, even if you don't use the power you have available to you.
Get some DVC 6x9's speakers for the rear and you can get twice as much power out of your deck... 50watts RMS normally... per speaker, then you can use an amp for your subs and one for the front... this being the cheapest method... or go with a 4-channel 2 for the front 2 for the subs...
Car: 89 IROC-Z
Engine: 355 TPI
Your average headunit puts out between 26 and 28 watts rms
Anyway, moving on. 5% THD at 20hz, 50hz, maybe even 100hz is almost inaudable. 5% THD at 1khz to 2khz is probably enough for you not to even be able to recognize the song you're listening to.
At the extreme ends of our audible spectrum, THD can be much higher without us recognizing it. In the most sensitive range of our hearing, we are VERY capable of discerning small amounts of THD. I would be willing to bet that at 1khz, anybody on this board could hear 1% THD. I'll bet that some of us could even hear .1%.
Anyway, all that crap aside, a good solid 4x50 amplifier will get SUBSTANTIALLY louder than any head unit. In theory, it should only be a 3dB difference between 25 watts and 50, but in reality, the power gap is considerably wider. Realistically, you're seeing a difference of 10-15 watts to 50-75 watts.
While a head unit might be able to push out 25 watts into a resistor at whatever THD and whatever bandwidth it's rated for, it falls on its face when it tries to drive the dynamic load that a loudspeaker presents to it. A better quality amp, like a good name brand 4x50, is less likely to suffer the same problems driving a dynamic load, and will make it's rated power.
The output from my girlfriend's Phoenix Gold T400.4 (rated at 4x50) is very, very impressive. I'm using 2 channels to push a pair of CDT components, and the other 2 bridged into a 2 ohm load (2 paralleled 8" subs). It pounds way harder than 200 watts has a right to.
I guess I didn't realize that DVC 6x9's are that rare... I have some in my car and I really haven't searched around much since then... my mistake
Car: 89 IROC-Z
Engine: 355 TPI
I didn't even what to get into things like damping and all. There's a lot that comes into play.
Basic: Internal amp not as good as external amp.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Originally posted by Justins86bird
What's the wattage stated on the certificate?
Car: 92 caddy PIMP
Engine: 4.8
hehe...I see all your points about head units crappy power....I agree that if your not looking for very loud bass out of your subs then go for it(the 5 channel.). But you might end up leaning towards another amp in a year and youll say to yourself. Why did I buy this 5 channel anyway...?
Nate
Nate
if it was 1ohm stable x 4 channels... then wouldn't it be a total of 1040 RMS watts?
65 x 4 @ 4ohms = 260 RMS watts
130 x 4 @ 2ohms = 520 RMS watts
260 x 4 @ 1ohms = 1040 RMS watts
I would assume at 1ohm, that this amp would be highly distorted, but I've never used it... I've always heard its better to have 4 or higher ohm load, if you have enough watts at that ohm rating...
The power only doubles for as long as the power supply can keep feeding the current, so eventually you will hit a wall.
Anyway, to clarify, the amp is rated at 50x4 into 4 ohms, but is 1 ohm stable per channel. I've got a pair of 4 ohm Tangbands paralleled on 2 bridged channels, so those 2 channels see a 1 ohm load each.
Car: 86 Z28
Axle/Gears: TBD
i have a 5channel amp thats great planet audio
it has 100x4 for interior, 300for sub
planetaudiousa.com oh by the way, the specs are listed at 13.6volts dc
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
like vibrations?? becuase i kno the alienware alx comps run some serious power and have liquid cooling.. im sure tho it would suck to have ur coolant go into ur amp and short it out
with the horrible bumpy ride in the rear I would presume that liquid cooling would not be a good idea... but then again, maybe that's all been thought out before hand, I just wouldn't think anyone could fit a system that required liquid-cooled amplifiers in a thirdgen
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
skinny z
Oct 5, 2015 06:23 PM
