my bass died..kinda
Old Dec 9, 2004 | 07:31 PM
trajik's Avatar
Car: 1987 Camaro
my bass died..kinda
So today I turned on my car, put the faceplate on the radio as usual and I noticed the bass was hitting really weak. I have two 10's in the back that are fairly decent, I checked all the wiring in the trunk and everything seemed in place, made sure all the settings on the radio were correct and everything, but they are still hitting very weak, like 1/4 potential.. I also tried turning it up on the amp but it only helped a tiny bit. (still sucks!)
I'm a complete newbie when it comes to car audio help me out here please
Old Dec 9, 2004 | 08:30 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
just hope you didnt punch the subs...
you are supposed to let your subs and speakers warm up when you fist listen to the radio..
its like letting your car warm up... you wouldnt just start the car and take it down the 1/4 mile right..
see if the subs are still moving..that will be a good indication of whats up..
if not...reinstall the head unit (piece that comes off) maybe it wasnt in all the way
iroc2nv
Old Dec 9, 2004 | 09:01 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
iroc2nv
electrical components work more effeciently when they're cold. this is why before any competition you dont play your subs for the whole day so they're fresh (also so your batteries are fully charged).
it sounds like your subs are somehow out of phase....it could be a phase adjustment on your deck or on the amp
Old Dec 9, 2004 | 11:18 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
maybe a wire came loose connected to the sub inside the box.. did you check that? happened to me once.
Old Dec 10, 2004 | 10:08 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
iroc2nv
i think you are mistaken a little.. ive heard, not sure on this tho, that you should let your subs break in b4 you start to crank it...
Old Dec 10, 2004 | 10:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what needs to break in on a sub?
Old Dec 10, 2004 | 03:04 PM
86irocznj's Avatar
chiming in!
ok pretty much ...heres what could be wrong with your subs
a terminal could be off in the box ...doubt it because then it wouldnt even attempt to play , if they dont hit as hard as they did before ...they could be blown and you might not notice it ...you need to hold the cone down and turn it up a little bit and see if they rattle if they do....BLOWN! ...and if they do hit and they arent as good as before ...did you forget the "gaskets" ill call them that since thats what they look like ...my subs were good but i didnt put the gaskets on and so i did and rescrewed them into the box with all 8 screws instead of like 3 like a friend did for me ...and boy did they hit like 30000 times harder ...my setup was 2 rockford 12s and a power acustic amp ....the end ....not to bad best 2 12 setup i think ive seen ....im packing more juice into my camaro over the summer since i have a friend that wants to build me a box and such
oh and if they arent blown and you did put the gaskets on ...thennnnnnnnnnnnnnnnnnnnn you have a bad wiring connection somewhere ...are your RCA cables running to the trunk with your power? ...bad idea you get noise and they do effect performance ...dramatically ..., and if you dont have that then the problem lies somewhere between your head unit and the subs ...swap units if you have another one ...and see if it changes the difference of the subs, if not ...then start checking cables, if you live in the south jersey area ...im free tomorrow and tonight i could take a look!
Old Dec 10, 2004 | 04:30 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
some companies say their subs require break in....but when you see people with large multisub setups at competitions blow 2-3 subs every run then replace then with out of the box subs and play them again right away im a bit sceptical towards break in time.
it is a smart thing for manufacturers to say though, just so that you dont crank your subs up right away and blow them. If you let them "break in" at lower volumes you'll have a better idea of regular bass as opposed to distorted bass when you jack up the volume...thats my theory atleast
Old Dec 11, 2004 | 07:44 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Maybe your deck has reset the equalizer function controlling the subs? On my interim unit, it has a "loud" function that will randomly turn itself off, and hence the subs won't be very loud
Old Dec 11, 2004 | 09:27 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
you always want to keep the "loud" function off as all it does is disort all the signals. thats how you blow subs.
Old Dec 11, 2004 | 09:29 PM
HA, I could care less at this point, I'll be tossing it into my basement in a couple weeks anyway, besides, it was a $40 sub that I bought like 3 years ago when I didn't know better
wanext
Oct 6, 2015 12:18 AM
Ed Maher
Car Audio
Jan 31, 2001 08:31 PM
Sweet_85_Bird
Car Audio
Jan 18, 2001 12:57 AM
86V6
Car Audio
Jan 6, 2001 06:07 PM
junkyarddog
Car Audio
Nov 27, 2000 02:15 PM
