No Stock Wiring Harness?
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Well I was gonna install my cd player today but it seems that the stock wiring harness was cut out & a different 11 pin wiring harness in there which hooked up to the kenwood cassette player that was in there.Any suggestions?
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
cry?? id suggest getting a wiring diagram becuz you need to find each wire by color
Car: 1991 Camaro RS
Engine: 357cid
findin stuff like that online is hard.. my shop teacher tryed to get us to do that pretty often.... i use haynes manuals becuase they have all sorts of info and pretty good wiring diags.. good luck and make sure you dont go half *** becuz the fire would burn from the inside of you dash out...
Car: 1991 Camaro RS
Engine: 357cid
use butt connectors ( the kind that crimp on vboth sides) i would stay awy from blades or anyhting else
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
1982-87 Chevrolet Camaro Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Or just cut the wires on the HU side about half way and splice into the new HU wiring since they are most likely the same universal colors.
Blk=grnd
Yel=batt constant +
Red=ACC (on with ignition)
etc...
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Blk=grnd
Yel=batt constant +
etc...
Engine: 305 LB9
Yeah, I guess I should start searching for a stock wiring harness so I can put it back in, maybe Ill check at the junk yard sometime this week.
Engine: 305 LB9
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Blk=grnd
Yel=batt constant +
etc...
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Blk=grnd
Yel=batt constant +
etc...
Engine: 2.2
If it's not broke, don't fix it....
Sounds like some electronics guy took a leftover generic harness and used that to correct a missing harness.
you have the male and female sides with wires intact, the HU you have now works, why mess with it?
Unless you are intent on getting you car 'original GM' .....how many people here actually care about that?
Just use the chart above to double check the work, chances are you won't even need all of those connections.
Engine: 305 LB9
The kenwood is a cassette player and I want to install my Pioneer cd player...Unless theres a way I can take the adapter off the back of the kenwood & wire it on to the GM01 end of the wiring harness
Car: 1991 Camaro RS
Engine: 357cid
w/e you do.. make sure you make it easy enuff to get he headunit out if you need to
Engine: 305 LB9
yeah, I actually think wiring up the factory wiring harness would be easier now cuz theyre all color coded with the wires that are already in there and everything. Thanks for the help guys
