Amp Installation Help
Old Dec 25, 2004 | 03:44 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I got my steroe equipment from my wife for christmas and i will be installing it soon. I have a little knowledge when it comes to wiring these things. The box says that the amp is bridgeable, what does it mean to bridge an amp? I know that it has something to do with the way you wire the speakers and i think that i even knew at one time but i know no clue now.
Old Dec 25, 2004 | 04:42 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
Bridgable means you can combine the two channels into one. For example, if you have a 400watt x2, if you bridge them you can get 800watts x 1. But not always. What you do is, instead of putting one wire in the (lets say left) + and one in the left -, you would put one in the left + and the right -. Thats not always the case, if you look above or below where you put your wires, it should say something like
_bridged_
|+|-|_|+|-|
then you would put hte positive in the left side, and the negative in teh right. This is best when you're running one sub since most are only 4ohm stable. If your running two 4ohm subs, when you bridge them you get 2ohms and your amp will go into protection mode.
Old Dec 25, 2004 | 05:04 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
just to let you know, to my knolage if you have a amp that is 400watsx2 and you brige it it will give you 400 wats into the speaker 400x2 meens 200want per speaker for EX1 12in would get 200 and the other would get 200. the type of sub has a lot to do with it to, is the subs a dule woice coil of single.
Old Dec 25, 2004 | 08:12 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
that is not quite true, i don't know the formula but when you bridge an amp you get more power, similar to changing the ohms of the amp. i.e my amp is 400x1 at 4 ohms and 800x1 at 2 ohms.
Old Dec 26, 2004 | 03:51 PM
GTAfanatic's Avatar
cool thanks for info
Old Dec 29, 2004 | 05:32 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I have two subs. So i would put both positive wire into one terminal and both negatives into the negative terminal?
Old Dec 29, 2004 | 08:19 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
is it a 2 channel amp or a 4 channel?
Old Dec 29, 2004 | 09:36 PM
jovial86's Avatar
Yup, you twist them together and put them into the same terminal. The L+ and the R+ into the bridged + terminal, and the L- and the R- into the bridged - terminal.
Old Dec 29, 2004 | 09:47 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i think its a 2 channel. I bridged it and it sounds awesome. Thanks for all the Info!
RazorN8
Jan 7, 2022 11:44 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
SPEEDY Z28
Aug 17, 2015 01:46 PM
