Components Kappa vs Perfect
Old Mar 13, 2005 | 07:14 AM
BLOWN25TH's Avatar
Car: 25th Anninversary Z28
Engine: Pro Charged 355
Transmission: Built 700R4
I am looking to put a set of component speakers in some kick panels on my 92Z. I am looking for some feedback on the sound quality of the Kappa and Perfect series component speakers.
Currently i have a Clarion 845MC, Kappas all around with a small 4 channel Alpine amp. 4X6 plates in front (which i am very dissaponted with) and 6X9's in the sail panels (which sound pretty good). Everybody says to go with components in the kick panels for good imaging so i am considering it. But i want to make the right decision on which series to go with for total sound quality. Or maybe even another brand if i can be convinced. Thanks in advance.
Old Mar 13, 2005 | 09:05 AM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
Go with the perfects if you have the money.
Old Mar 13, 2005 | 01:27 PM
lavamadness's Avatar
Car: 1989 Formula 350
Engine: 5.7L (L98)
I can't comment about the Kappas, but I've got the Perfect 6.5s right now. I've found the tweeters to be rather harsh, and the midbass lacking. If you search the net, these also seem to be common complaints. Especially about the tweeters.
Old Mar 13, 2005 | 01:30 PM
BLOWN25TH's Avatar
Wow, that is the first complaint i have heard about the Perfect's. How much power are you puting to them?
Old Mar 13, 2005 | 02:29 PM
Engine: 5.7L (L98)
The recommended 100w rms from a Kicker KX800.4.
Old Mar 14, 2005 | 07:26 AM
BLOWN25TH's Avatar
I am not running nearly that much power. I have a 50X4 RMS alpine amp. Pretty small. How do you calculate RMS? Do add your head unit and amp RMS to get your total or just your amp?
Old Mar 14, 2005 | 08:16 AM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
Just your amp. Depending how you have your gains set, it could be running below, above or at 50w as well.
Old Mar 14, 2005 | 11:32 AM
BLOWN25TH's Avatar
Well it sounds like i am under powered. Should i have my gains set all the way up since i am under powered on both my fronts and backs? I have Kappa 4x6's in front and Kappa 6x9's in the back.
Old Mar 14, 2005 | 02:53 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
no because if you try to turn the gains all the way up your amp will strat clipping and you blow your speaker.
Old Mar 17, 2005 | 01:41 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
if the tweeters sound harsh, then you need to adjust your EQ... I've got nothing but praise for those perfects... the regular kappas sound a tad drab to me, (only in comparison to the perfects...)
get the perfects, you'd not regret it.
if the tweet is too harsh, check your headunit/amplifier settings...
RedLeader289
May 28, 2019 01:47 PM
Briandrex
Oct 5, 2015 06:20 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
meeklay812
Oct 1, 2015 03:46 PM
