Check out the Box I made..
Old May 15, 2005 | 07:09 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
I think this is pretty good for building a box my first time but check this out, I covered it in vinyl it has 2- 8" JL audio subwoofers in it. it was made outta 1/2" mdf material, and i just got finished capping the ends, it fits perfect under my notchback. it's actually pretty complicated to build and i didn't have any power tools so i had to cut it all by hand.
Old May 15, 2005 | 07:12 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
progression pics.
Old May 15, 2005 | 07:13 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
another
Old May 15, 2005 | 07:15 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
more more more
Old May 15, 2005 | 07:17 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
another another another
Old May 15, 2005 | 07:19 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
more here there everywhere
Old May 15, 2005 | 07:21 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Yeeehaw... << nobody says this in NY
Old May 15, 2005 | 07:22 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
I capped off those ends cuz i never covered something in vinyl before.
Old May 15, 2005 | 07:24 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
last pics... of in the car.
Old May 15, 2005 | 07:26 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
last pic..shim shim salabim!!!!
Old May 15, 2005 | 09:24 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Ooops I forgot about that silly picture rule thing.... here's the links guys.
http://www.geocities.com/gokuirocz/start01a.jpg
http://www.geocities.com/gokuirocz/start03a.jpg
http://www.geocities.com/gokuirocz/start05a.jpg
http://www.geocities.com/gokuirocz/start04a.jpg
http://www.geocities.com/gokuirocz/start06a.jpg
http://www.geocities.com/gokuirocz/start07a.jpg
http://www.geocities.com/gokuirocz/start08a.jpg
http://www.geocities.com/gokuirocz/start09a.jpg
http://www.geocities.com/gokuirocz/start11a.jpg
http://www.geocities.com/gokuirocz/subcom1.JPG (Completed in car)
http://www.geocities.com/gokuirocz/subcom2.JPG (Finished)
Old May 15, 2005 | 09:45 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
looks good bro!! How does it sound?
Old May 16, 2005 | 09:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It looks pretty impressive considering you had to cut everything by hand.
When you get ambitious enough to try your 2nd box, I'd suggest stepping up to 3/4" MDF, and when you vinyl the box, you can use some spray adhesive and wrap it right around the enclosure so that there aren't any bolts showing on the front panel. It'll give a more seamless integration to the interior.
If you can effectively seal off the area between the interior and the hatch area behind the sub box, you'll find a good improvement in sound quality because you won't suffer from the typical cancellation that happens when the subs aren't all the way at the back of the car. I can see tremendous potential for a great sounding setup like this in a notchback car.
Old May 16, 2005 | 11:32 PM
Javelin3o4's Avatar
Car: 1971 Camaro
Transmission: TH350
yeah good job, i know i wouldnt have the patience or even want to cut all that by hand.
Old May 17, 2005 | 11:27 AM
sesand's Avatar
Car: 1992 Firebird T-Tops
Engine: V6
That's an interesting design. 5/8" mdf is as small as I would have gone, but nice job overall.
Do you have any pics from the back with the hatch up?
Old May 22, 2005 | 10:33 AM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
Actually I just checked. and I did use 3/4 I thought I used something smaller lol.
Old May 22, 2005 | 06:14 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
As Requested a Picture with the Hatch up and the T-tops in the bag (the whole reason i made this box was so i could store my t-tops in the factory spot) haven't gotten around to capping the corners yet tho.
Old May 22, 2005 | 06:20 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
another
Old May 22, 2005 | 10:11 PM
sesand's Avatar
Engine: V6
That's pretty sweet - did you cover the plastic panels with red carpet?
Nice work!
Old May 25, 2005 | 11:59 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Nice work!
That's an option, deluxe interior package. Forgot what else it came with though.
Box looks good, very different setup than from what I've seen!
MyRedCamaro
Dec 29, 2015 05:16 AM
snowflake
Oct 19, 2015 10:24 PM
backtothe80s
Sep 5, 2015 12:39 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
