Pics of AC duct Install???
Old May 31, 2005 | 01:15 AM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Does anyone have a pic of anything (HU or screen) installed in the centre AC ducts?
I searched quickly but only found people talking about doing it, and no pics of it DONE or what involved with doing it.
Any help would be MUCH appreciated.
Old May 31, 2005 | 08:41 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
One of these days I'm going to cut up my spare dashboard to make a new trim piece for around the DVD player that looks more stock. The ABS one doesn't look too bad in person, but reflects the camera flash and looks odd in pics.
Old Jun 1, 2005 | 01:25 AM
traksta15's Avatar
Car: on the hunt for a 3rd gen again
that looks awesome.....how hard was it???
Old Jun 1, 2005 | 07:15 AM
Jim85IROC's Avatar
I guess that would depend on your talent level. It took me over a month, and required a 2nd dashboard that I could cut up and install. At least now I know what my firewall looks like from the inside.
Old Jun 1, 2005 | 10:20 PM
Nice, and thanks for that.
Just a quick question;
Would the single Din fit without re-boxing the area like you have done? I was hoping a unit would fit in by removing the ducts and sawing out the middle cr@p.
Also, what exactly is in there behind the ducts? Anything 'solid'?
Old Jun 2, 2005 | 08:06 AM
Jim85IROC's Avatar
If you just remove the center bar between the 2 louvered vents, I don't think there will be enough room to fit a single DIN unit. I removed that entire front area and replaced it with that flat ABS panel. If I ever get time, I'm going to make a cover out of the piece that I removed to hide it, but that's not likely to happen for a while.
One thing that I would caution about is that on a car that gets a lot of miles, you're going to want to reinforce the dashboard to prevent cracks. These dashboards all crack in the corner above where the center console lines up to the dash, and with that extra weight on top, it's going to get worse. I reinforced the back side by attaching thicker ABS pieces with a plastic epoxy. I don't drive my car much so I didn't add any reinforcement up next to the DVD player, but if you drive the car much you should do that too. There's a metal support bar that you've got to remove in order to fit the unit there, so having something else there to support it would be wise.
Old Jun 6, 2005 | 04:32 AM
1320 Right Ln.'s Avatar
for the screen frame, did you just cut and shape another center section? Also, what kind/size screen is that, and how did you get rid of the middle bar and still end up with a smooth flat surface on the inside? That looks pretty nice, I hope you don't mind if i copy your design sometime in the future.
Old Jun 6, 2005 | 08:03 AM
Jim85IROC's Avatar
The screen is a 7" screen.
I've got a step-by-step picture tutorial of the entire process on my sounddomain page. Just click the link in my sig. Making that housing took a tremendous amount of work and wasn't easy.
1992rs/ss
Jan 31, 2025 05:10 PM
aaron7
Aug 17, 2016 06:02 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 26, 2015 04:59 PM
sonu1975
Aug 11, 2015 08:38 AM
