i need help!! l@@k inside
Old Aug 6, 2005 | 09:59 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i cant get any power to my amp at all whatsoever. i have tried everything. i have 4 gauge wire and an 80 amp fuse in a fuse holder. the fuse is good and all the wires seem to be hooked up right. i cant get any power from my battery. but i put the ring on the battery and screwed the positive terminal down on the battery and i get power to everything but the amp. whats the problem?? let me know what you think so i can get it all fixed by tomaro. if i did not give enough or the right information let me know.
Old Aug 7, 2005 | 02:00 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
your remote wire is hooked up correctly??? hows your ground??? did you try a test light on the power wire yet?
what i would do is make sure your remote wire is hooked up correctly.... then i would take a test light and see if the wire is acctually getting power....to where the amp power terminal is.... and then i would check your amps ground.....if all those check out.. well then you might have a bad amp
Old Aug 7, 2005 | 03:29 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
to test your remote wire (should be blue or blue with a white stripe) disconnect it and connect it to the power wire, if it powers on you know you had it wrong before (is that spelled right? before? i am a little intoxocated right now ) or you can turn the deck on and test light the remote wire.
if you are going to ask what a remote wire is, it is the wire from your deck that tells the amp to turn on.
i think that prety much summs it up...
right, time for more booze!
Old Aug 7, 2005 | 06:22 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
ya you need
A. power
B. remote turn on in thats not blown.
C. A good ground
for an amp to turn on.
Old Aug 7, 2005 | 03:49 PM
Car: 88 IROC
thanks captain obvious.....
Originally posted by ddn69
ya you need
A. power
C. A good ground
Old Aug 7, 2005 | 03:51 PM
Car: 88 IROC
i figured out the problem though i used a volt meter on my power wire and i was actually getting power it was my remote wire that got messed up so i recrimped it and now its good... so thanks for the replies.
Old Aug 7, 2005 | 08:04 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
your welcome
Old Aug 10, 2005 | 10:30 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
You forgot to capitalize his name... since there's no way that was sarcasm.
Considering you asked us pretty much the most vague question ever posted on these forums. What exactly were you expecting?
From your first post, I'd assume you didn't even connect a ground wire, which might be why ddn69 included that in his 'obvious' list. He wasn't exactly sure that this would be 'obvious' to you, I'm guessing.
Glad you figured out your problem
Old Aug 10, 2005 | 10:35 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If it is so obvious, why did you ask your question?
Old Aug 10, 2005 | 01:49 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Well you obviously don't have one of the three, and unless you're a water head, it shouldn't be hard to figure out why.
If you don't have 12 volts at your amp, then there's a discontinuity in the line somewhere between it and the battery. That leaves the connection to the amp, the wire itself, the connections at the fuse holder, the fuse, or the connection at the battery. Take your volt meter and work your way to the source until you isolate where you don't have power and you'll have your answer.
Old Aug 10, 2005 | 04:27 PM
ScrapMaker's Avatar
I think he actually figured it out already.
Old Aug 11, 2005 | 06:58 AM
Jim85IROC's Avatar
Oh yeah. I guess I skimmed over that part. How ironic that Capt. Obvious had his answer all along.
Old Aug 13, 2005 | 10:16 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Oh and the fact that I put...GOOD REMOTE WIRE> which ended up being his problem...
Old Aug 13, 2005 | 10:47 AM
Car: 88 IROC
well i didnt think it was any of those problems b/c the wirring was perfect a couple days b4 when i used my friends sub but when i hooked up my sub it didnt work so i didnt think it was any of those things. but i ran a volt meter on it and fiqured out one of the crimps on the remote wire had came loose so i fixed it and now its all good.
Old Aug 13, 2005 | 01:25 PM
ScrapMaker's Avatar
just don't expect much help in the future
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
