anyone ever stuff a 12" woofer inside the area where the rear glove box is?
Old Sep 25, 2005 | 06:28 PM
BOTTLEDZ28's Avatar
Transmission: A4
Has anyone ever built a box to house a 12" sub that rest inside the area where the rear glove box is located. I really want a to add a 12" woofer to the rear of my car but I do not want it exposed at all. Is trying to put one their a bad idea for sound or is there just not enough room? How much space is need for the average 12" woofer, 1 cu ft? Oh and I do not want to cut any of my sail panels to do this. I can loose the glove box though and I cant use the passenger side since that will be the new home for a nitrous bottle.
Old Sep 26, 2005 | 01:44 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
https://www.thirdgen.org/techbb2/sho...5&pagenumber=4
jrmaata's post shows his sub boxes in the glove box area and spare-tire area, might want to ask him what he thinks of the sound quality.
Old Sep 28, 2005 | 09:51 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I have a fiberglass box for that area, but it only holds up to a 10" with .5 cu.ft. of airspace. If you really made it complicated, you could get some extra airspace out of the small well area below, but I don't see fitting the actual 12" cone between the hatch and the trunk shelf, it's just too tall. If you moved the cone toward the side of the car so the bottom of the surround was actually below the line of the trunk shelf, then you would have even more limited mounting depth.
to summarize.... Good Luck!
Old Sep 28, 2005 | 03:56 PM
BOTTLEDZ28's Avatar
Transmission: A4
thanks for the tip. The only problemwith me using a 10" woofer if the fact that I already have a 12" woofer. I guess if push came to shove, I could get a 10 but it would have to be a really good one.
Old Sep 28, 2005 | 03:59 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Can you get a nitrous bottle that will fit in the driver side, and then use the pass side for your sub? That might be the better option.
Old Sep 28, 2005 | 04:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
Not sure if a 10lb bottle will fit in there but I will check on it
Old Sep 28, 2005 | 04:31 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
yeah I do not think the bottle fits in the drivers side. In such a small enclosyre, you would have to have a ported box to somewhat keep the CF smaller. Too little CF for the sub will make it sound weaker than a 10 with the proper CF.
Old Sep 28, 2005 | 05:02 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Actually ported boxes require more airspace. The super small box for the 12 wouldn't sound weak, it would just sound really loud and annoying.
Old Sep 28, 2005 | 05:17 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
a good 10"? i have Solo Baric's in mine... DAAAMN loud for a 10"
but yeah a 12" is nice
Old Sep 28, 2005 | 05:52 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
...or a W7 could fit as well.
Old Sep 28, 2005 | 06:35 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Are you making the stealthboxes again ?
Think you can possibly change the mold a little to reach further down past the ledge allowing for a little more airspace ?
1992rs/ss
Jan 31, 2025 05:10 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
z28addict8490
Aug 7, 2015 08:48 PM
